Technicolor TG582n Firmware Update
- Technicolor TG582n Firmware Update
23-09-2013 4:23 PM
My Technicolor TG582n Firmware Release is 8.4.4.J and would like it updated to the latest release which I believe is 10.2.5 or something similar.
Can this be done please?
Message 1 of 9
(11,711 Views)
8 REPLIES 8
Re: Technicolor TG582n Firmware Update
23-09-2013 11:47 PM
Message 2 of 9
(2,269 Views)
24-09-2013 9:16 AM
Message 3 of 9
(2,269 Views)
24-09-2013 3:38 PM
Thanks Machare for pointing the way.
Just to confirm with Adam;
I have Windows 7 with the Technicolor TG582n (without USB) Router connected through PlusNet.
I have Flashing Util: TG_UPGRADE.zip & Firmware Flash File: PN TG582n R10.2.2.B EH.bin.
Does this seem all correct to you, and is 10.2.2 the latest firmware?
Message 4 of 9
(2,269 Views)
24-09-2013 4:51 PM
Message 5 of 9
(2,269 Views)
24-09-2013 7:38 PM
Quote from: kheemonahs I have Windows 7 with the Technicolor TG582n (without USB) Router connected through PlusNet.
I don't think that flashing utility works on Windows 7. You need the Windows 7 version (Windows 7 Upgrade Tool.zip) from this Community Library article.
David
Message 6 of 9
(2,269 Views)
26-09-2013 1:13 PM
Thanks for that spraxyt , I probably would have wasted a lot of time and maybe bricked the router trying to use the wrong installer version.
Ever thought of joining Plunet Staff as an adviser
So to re-confirm;
I now have Flashing Util: Windows 7 Upgrade Tool.zip (TGUPGv7210) & Firmware Flash File: PN TG582n R10.2.2.B EH.bin.
Does this seem all correct?
Message 7 of 9
(2,269 Views)
26-09-2013 3:10 PM
Those files seem the correct ones to me.
David
Message 8 of 9
(2,269 Views)
26-09-2013 3:23 PM
Thank you, will update over w/e.
Message 9 of 9
(2,269 Views)
