Technicolor TG582n FTTC & SNTP Error
- Technicolor TG582n FTTC & SNTP Error
22-01-2013 11:44 PM
SNTP Unable to contact server: 212.159.13.50
Doesn't appear to matter what ntp server I try, tried the *.uk.pool.ntp.org ones and they don't work either. My router was restarted 2 days ago and it now thinks it's Jan 3rd dunno what year.
It doesn't appear to be affecting it in anyway so does it matter? and or anyone discovered this before and know of a fix?
Re: Technicolor TG582n FTTC & SNTP Error
23-01-2013 9:02 AM
I use the following on my TP-Link without any problems :
194.164.127.5
130.88.203.12
23-01-2013 11:53 AM
Time not updating suggests something is wrong with the internal set-up. I suggest trying a factory reset and let it set itself up again.
25-01-2013 10:17 PM
The reason I wasn't using the ip-addresses was simply because it would defeat using the ?.uk.pool.ntp.org as the 4 possible addresses are dynamically assigned from a list of something like 200 different time servers.
Anyone got any recommendations for good routers that do VPN site to site using an iPsec tunnel?
25-01-2013 10:36 PM
26-01-2013 12:01 AM
26-01-2013 1:34 AM
19-01-2014 8:56 PM
Must be a firmware bug.
Will it be fixed in an update soon? Mine is running 10.2.5.2
It is annoying because the logs all tell the wrong time without it.
19-01-2014 9:20 PM
19-01-2014 9:25 PM
Quote from: ejs See: https://community.plus.net/forum/index.php/topic,113730.0.html
If the Plusnet Broadband Firewall set to "high", then ntp won't work.
See What would cause TG582n to not connect with time server(s) (SOLVED)
19-01-2014 9:38 PM
Still once per minute there is a message saying could not connect to SNTP server.
Other devices on the network in the house use NTP and work.
19-01-2014 9:59 PM
I get a reply here but it a tad slow considering I'm on the same network.
Pinging 121.159.13.50 with 32 bytes of data:
Reply from 121.159.13.50: bytes=32 time=296ms TTL=48
Reply from 121.159.13.50: bytes=32 time=302ms TTL=48
Reply from 121.159.13.50: bytes=32 time=295ms TTL=48
19-01-2014 10:20 PM
20-01-2014 11:24 AM
20-01-2014 12:07 PM
Other devices (webcam and android ntp client) seemed to work anyway, so I'm not sure why they work if a blocked port #"123" is to blame.
