Technicolor Gateway
- Re: Technicolor Gateway
Technicolor Gateway
12-02-2017 7:50 PM
Why do I all of a sudden get this come up:
In the last hour it has popped up 3 times, when it does I lose the page that I was logged into.
13-02-2017 12:26 AM
Most likely reason is that your router has resycned, which probably means you have connection problem. If it isn't too late.log into the router and take snapshot of the logs and post them on here. Someone may be able to advise you further after looking at the logs.
14-02-2017 2:54 PM
As @jab1 suggests, this can happen if the line is disconnecting frequently.
It looks like your connection has stablised since the post, if you start having issues again I'd advise getting this reported to us as a fault at https://faults.plus.net
