Technicolor 582n
- Technicolor 582n
Technicolor 582n
26-06-2013 5:19 PM
Reading reviews, it appears to be a poor device, with poor wifi range and very poor speed, and the web ui being rather restrictive.
Is there a full online manual of this device I can skim through to see if it's up to scratch? Is there anywhere that specifies full specs (i.e. I read that the wired ethernet ports are only 10/100)
If it isn't suitable for my needs (which again, I am assuming not), what do I need to look out for to buy a replacement? Are any users using a third party device that does the following at minimum:
DHCP Server, with assignment of static IP addresses
QOS
Port forwarding that will allow a web server to be hosted (I occasionally develop web sites and use it as a test bed)
True VPN
Also, I previously paid for a static IP address. Will this change? Will I still have a static IP?
Re: Technicolor 582n
26-06-2013 5:20 PM
You can find the info about the 582n here: http://community.plus.net/library/hardware/tg582n-information-and-specifications/
The fibre specs are partway down the page.
27-06-2013 1:07 AM
Looks like another job for wiii-cycle man.
So. Can I use my existing adsl modem instead of this? Obviously I would connect the openreach box to an ethernet port and... well, I don't know.
What do I need to look for to get a proper specced router that'll work with the openreach box, rather than the micky mouse wind up toy I've ended up with. Would a standard cable router work?
27-06-2013 1:13 AM
Plenty of threads on the forums about alternative routers - use the Search Force, Luke...
27-06-2013 8:59 AM
Quote from: Chinners So. Can I use my existing adsl modem instead of this? Obviously I would connect the openreach box to an ethernet port and... well, I don't know.
Unless it has a specific WAN port that can establish a PPPoE session using your PN credentials - no.
Cable routers may be OK.
27-06-2013 9:18 AM
Quote from: Jaggies Plenty of threads on the forums about alternative routers - use the Search Force, Luke...
I've just started on this journey... and have only found page after page of bad news. On other non-related forums, I have only heard 1 good comment - "it works, but I don't do anything other than surf the web".
Now I have half an idea what I have to look for, and now the initial feeling of "being fooled" has passed, I will commence my search.
Quote from: jelv Unless it has a specific WAN port that can establish a PPPoE session using your PN credentials - no.
Bum. Looks like my current gadget is destined for e-bay then. I can put the pennies earned towards a
27-06-2013 9:30 AM
What make/model is your existing router ?
Quote So. Can I use my existing adsl modem instead of this? Obviously I would connect the openreach box to an ethernet port and... well, I don't know.
Do you mean VPN endpoint support or just VPN passthrough ?
Quote True VPN
27-06-2013 9:31 AM
Quote from: Chinners Looks like my current gadget is destined for e-bay then.
Don't! Having a spare router provided by your ISP is a good idea in the event of you having a fault as it can be used to eliminate the router from an investigation.
27-06-2013 9:47 AM
Quote from: MisterW
What make/model is your existing router ?Do you mean VPN endpoint support or just VPN passthrough ?
Quote True VPN
Currently using a cheapish Netgear thingy - Model number escapes me (I'm at work at the mo) It is VPN Passthrough that is essential.
Quote from: jelv
No, I wouldn't dream of selling the one supplied by plusnet. As you say, it'll be useful as a backup, or keeping the room warm. I meant flogging off my Netgear.
27-06-2013 10:11 AM
Almost certainly a DG834 of some variant I would guess, in which case definitely doesn't have a WAN port. All routers should be capable of VPN passthrough.
Quote Currently using a cheapish Netgear thingy - Model number escapes me (I'm at work at the mo) It is VPN Passthrough that is essential.
27-06-2013 2:46 PM
i would like to change out my Thomson TG582n with Sky's SR101-z ?
I tried setting it up, but while it sees all Local Connections, it doesn't register internet connectivity. Obviously something more i've got to do in the settings.
Don't want to hi-jack your thread with set-up details, but would like to know is this worth pursuing and do-able?
Many thanks
27-06-2013 3:04 PM
Most SKy routers are 'locked' to Sky I'm afraid
Quote Sky's SR101-z ?
27-06-2013 3:18 PM
Quote from: WonderWabbit This thread interests me as i have an alternative router provided by Sky:
Many thanks
Feel free to use the thread.
I think we are both in the position where we don't want to use the plusnet "approved" jokebox, and I am sure I may need help configuring my replacement anyway.
To me, it seems odd that for plusnet's flagship product, they give you this pooter.
It's like buying a BMW M-class, but having to sit on a bar-stool to drive it.
27-06-2013 3:20 PM
Quote from: MisterW Almost certainly a DG834 of some variant I would guess, in which case definitely doesn't have a WAN port. All routers should be capable of VPN passthrough.
Its an old, dusty but capable DGN2200...
27-06-2013 3:24 PM
