Technical question about speed vs distance from the echange
- Technical question about speed vs distance from th...
Re: Technical question about speed vs distance from the echange
23-07-2011 1:26 PM
Quote from: Carl I'm transferring both over but believe the phone line moves over a couple of weeks after broadband, is that right? If it means getting things sorted then I am happy to wait a couple more weeks.
Yes, that's right Carl, the broadband first and phone afterwards.
Quote from: Oldjim In your case, when the problem is sorted I would expect an upstream noise margin in excess of 20dB and downstream of about 12dB or perhaps more as you will be restricted by the speed limit on ADSL1 (8,128kbps when interleaving is switched off)
Maybe I'm just reading that wrong, Jim, but you do realise his services aren't with us yet?
Jojo
23-07-2011 5:40 PM
My answer was related to the general question of attenuation and noise margin and has nothing to do with who supplies it
23-07-2011 5:48 PM
25-07-2011 8:54 AM
Oldjim's post here is spot on so I won't go over SNR again, but don't worry about logging the crossed lines - one instance is sufficient for us to investigate further. A BT engineer will be needed (assuming the problem continues) but this is a pretty standard fault so there shouldn't be too much trouble getting the visit arranged.
31-07-2011 10:23 AM
Bandwidth (Up/Down) [kbps/kbps]: 320 / 192
I can't see any mention of noise or attenuation on the Thompson router. I believe the line is still with my previous provider for the next couple of weeks.
What would be my next step? Call support, or can one of the lovely support people take action from this message? 😉
Carl.
31-07-2011 4:15 PM
31-07-2011 5:31 PM
Link Information
Uptime: 1 day, 20:10:45
DSL Type: G.992.1 annex A
Channel mode: Fast
Maximum Bandwidth (Up/Down) [kbps/kbps]: 376 / 192
Data Transferred (Sent/Received) [kB/MB]: 0.00 / 205.65
Output Power (Up/Down) [dBm]: 12.5 / 11.0
Line Attenuation (Up/Down) [dB]: 5.5 / 13.0
SN Margin (Up/Down) [dB]: 7.0 / 7.0
Vendor ID (Local/Remote): TMMB / TSTC
Loss of Link (Remote): 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 0 / 1
HEC Errors (Up/Down): 0 / 0
Carl.
31-07-2011 9:05 PM
Can you plug the router into the test socket with nothing else connected and report the stats (the test socket is the one behind the lower plate on the master socket)
However the cross talk problem could be doing it - so will need sorting
Just to add the good news - once it is fixed you will get very fast speeds indeed - on ADSL2 in excess of 20,000kbps probably
31-07-2011 10:24 PM
Quote from: Oldjim Something is horribly wrong
This is a new house, there isn't a test socket. BT terminates outside and the housing association electrician wires the house & connects to the plastic BT box. I have opened the plastic BT box and half is marked as BT only & closed off. The other half has the connectors where the wire from the house connects. A local BT engineer told me this is the way new houses are connected now. For problem solving it adds another third party into the loop... I have spoken to the electrician who wired these houses and he tells me there is no electronics in the house, only wires, so they either work or the don't. I have three sockets in the house and the phone works in all of them, as did my previous router, albeit slowly. The only other device I have connected to the line is my phone which is connected to the same filter as the router. I will try the router without the phone connected when I get a chance this week. I have tried it before with the previous ISP and it didn't make any difference.
Quote However the cross talk problem could be doing it - so will need sorting
The local exchange is maximum 8Mbps & I believe the expected speed for this street is 7.5Mbps, although neighbours claim they are getting 8Mbps. That's plenty for me though 🙂
31-07-2011 10:42 PM
I think some photos of the various junction boxes and socket wiring (and the external NTE) are required....
31-07-2011 11:37 PM
jim:quote
01-08-2011 7:37 AM
01-08-2011 8:32 AM
10-08-2011 9:59 AM
When you signed up for your broadband account, we performed a check on your telephone line to give you an estimated speed your line might achieve.
Now that your service has now been active for 14 days, we thought we'd let you know the speed as it stands today, by way of comparison.
Estimated line speed: 0.5Mbps
Current line speed: 0.25Mbps
You can keep a track of your line speed through our website:
Does this mean that no further action is going to be taken to fix my line? I did also mention the crossed line problem, which is still happening, but no mention of that. Do I need to phone support now?
Carl.
10-08-2011 10:56 AM
Have you checked in the Member Centre for responses to your ticket? View your questions.
