Target SNRM Reduction
- Target SNRM Reduction
22-04-2009 10:59 AM
Has anyone got any tips on how to have my BT target SNRM reset to a lower value?
When my line was in its training period, there was a fault that required me to plug in at the engineers socket, try different filters and routers etc, and I now wonder if all that connect/disconnect resulted in my target SNRM being set at a high 15. It stayed solidly at 15 for almost a year, until I suddenly had an unexplained huge sync loss (from 1300 down to 800). Testing was done, and the offered solution was to reset my target SNRM down to 12 - and it did the trick - sync back to 1250'ish (and low errors/no dropouts)......and it has stayed at 12 ever since.
I was motivated to rewire all cabling from the master socket outwards, cut the bell wire, and get expensive microfilters. That seemed to improve things, and I embarked on a program of looking for the most suitable modem. I found that I could get stable sync rates of 1500+, with no dropouts and low error rates at a (starting) SNRM of 7'ish, which would then decay to 6.0/6.25 at the worst time of day, using a DG834G V4 with SNRM-tweaking enabled.
Having satisfied myself that my setup would cope with that SNRM of 6-7, I asked for Plusnet to reduce my target down to 9 - but my request hasn't been successful - I've been advised that if my line is good enough then the target SNRM should reset itself in due course.....does that seem likely?
Do you think it likely that I can persuade Plusnet to have my SNRM reduced to 9; are there any keywords/phrases that might do the trick?
Jack
Re: Target SNRM Reduction
22-04-2009 12:03 PM
Did you post all the information in your post above in the ticket? If not, post the ticket number here, post the information in the ticket, and add that you have approached things in a methodical manner to achieve the best from your line and see no reason to have to 'wait for the sytem' under the circumstances. A request to lower the target to 9dB is not unreasonable. Hopefully if this doesn't progress, one of the Comms team may pick it up.
22-04-2009 12:17 PM
Cheers,
Jack
22-04-2009 12:33 PM
22-04-2009 1:09 PM
For the whole of last year, I rebooted the router once a week, and as I've now found out, not at the best day/time - for me, the best is Monday at around 8 am, alternatively 8 am any day except the weekend. So according to whats been said about the DLM, my target SNRM would never had chance to re-set.
22-04-2009 2:05 PM
When swapping, leaving the modem/router off for as long as possible, running to hours even is never a bad thing.
24-04-2009 6:51 AM
"Unfortunately where we appreciate you do not want to wait for the change to happen automatically, BT will not perform manual SNR changes more than once per line, after that first change (which they are very resistant to do in the first place and only agree to in certain circumstances) if it goes back up they will never do another manually. We apologies for any inconvenience caused."
So be aware, it seems it isn't an easy matter to have your target SNRM changed, and even if you do, you get only 1 shot, so maybe go for the lowest possible, then let it find its own level.
25-04-2009 5:32 AM
I have heard of this male cow manure before.
25-04-2009 6:35 AM
However, Support have just now said there is a chance that BT may allow a further reduction to 9.....so I'll see if that occurs.
28-04-2009 4:15 PM
No waiting around for an Outreach engineer visit!
Excellent, and thanks to Support; so it can be done after all.
...and of course it has increased the sync rate (by 30%)
28-04-2009 5:26 PM
Quote from: jack21 Good-o !! Today, Plusnet Support asked BT to make the change - and 10 minutes later it was implemented.
Snap! Although I haven't asked for an SNR reset before on this line. I bet one of our faults analysts had to use some pretty aggressive persuasion to get diagnostics to reduce your SNR for the second time in a month!
Glad to hear it's sorted though
