TP-LINK AC1750 Dual Band Router
- Re: TP-LINK AC1750 Dual Band Router
27-02-2014 8:25 PM
Hi, Just wondered if you could help me deciding to buy this router tomorrow. Does the Tp-Link AC1750 have a built in modem, will be plugging into my BT master socket and In one or two of the reviews owners have said that they have had problems with connections to Apple devices, I have an Ipad1. I am considering stopping with Plusnet and upgrading my router instead of switching to BT just to get the HH4. Thanks for any advice..
adie:orange removed all caps title as per link:rules]
Message 1 of 6
(1,382 Views)
5 REPLIES 5
27-02-2014 9:19 PM
No, the Tp-Link AC1750 doesn't appear to have a built-in modem.
Message 2 of 6
(708 Views)
27-02-2014 9:20 PM
I have just ordered this myself. No, you have connect the Router upto the BT Openreach modem. It the same with the Home Hub 4 (the Home Hub 5 has the modem built in).
Message 3 of 6
(708 Views)
27-02-2014 9:32 PM
OK but what is an Openreach modem is that something I can order?
Message 4 of 6
(708 Views)
27-02-2014 9:39 PM
The Openreach modem is for Fibre (FTTC).
The Tp-Link AC1750 can't be used on its own with ADSL. You could get a separate ADSL modem to go with it, but it would be simpler, or at least result in having fewer boxes, to get a combined ADSL modem/router instead.
Message 5 of 6
(708 Views)
27-02-2014 10:27 PM
Wanted a router with a greater range than the Plusnet issued router or the HH2 that I am using now. Inf the WiFi range is important can you point me to a good router with maybe a modem built in . Thanks
Message 6 of 6
(708 Views)
