TI AR-7 based modems
- TI AR-7 based modems
24-09-2008 10:05 AM
Read a bit a while back there were some issues with Texas Instruments AR-7 based modems (I believe that the Netgear DB834N is one of these) although line has been stable since I moved to plusnet on lines with high attenuation.
Anyone know anything about this? purely out of interest)
Re: TI AR-7 based modems
24-09-2008 10:37 AM
This link might be of interest to you
http://www.theregister.co.uk/2007/10/22/zen_ar7_infineon_bt_fault/
I use a Netgear DB834GT which uses the Broadcom BCM6348 chipset and the thing is rock solid
24-09-2008 11:26 AM
Was just wondering whether it was a bit of a myth or something specific to the routers Zen was using to terminate their centrals (to clarify these are the big pipes to deliver the traffic from the BT ADSL ATM network) to your ISP
Had hprrendous problems when I tried O2 ADSL2+ (reason I left) but connection on plusnet has been rock solid (perhaps it communicates well at ADSL 2 with Juniper E series edge routers which is what plusnet use according to their network info)
Just trying to look into this as not sure whether to replacing my router might be necessary when 21CN arrives in my area as frankly the line is dire.
24-09-2008 12:17 PM
Once that hardware link is engaged, the rest of the traffic is ATM based and handled in software on the router - feasibly there are problems at this point, but it certainly wouldn't be dependant on the router chipset from here.
B.
24-09-2008 1:09 PM
Yes I've got a lot to learn about telecom stuff.
To be hones though, really wish that they'd hurry up and develop something better than ADSL because it has too many pitfalls.
a nice ethernet socket next to my PC linked directly to a fibre cabinet outside linked to plusnet's network would be nice, no router required and 100 meg speed
But of course it is expensive to build such a network so will have to make do with ADSL for a while
24-09-2008 2:03 PM
The best bet for the moment is FTTC, then DSLAMs at the cabinet. This will drop the ADSL segment length down to a fraction of the current Premises to Exchange length. This will mean that current (and new) technology can be designed to push the limitations of the copper pair, knowing that the line length will be much shorter than the current implementation.
Unfortunately, it also means a country-wide upgrade of kerbside cabinets, which I can't see happening under the current regime.
B.
24-09-2008 6:20 PM
Just wish Brown would spend it on stuff like cancer drugs to help people rather than the flaming Olympics.
Anyway I'm in danger of veering off into one of my other favourite subjects, politics which isn't appropriate for this forum.
24-09-2008 8:23 PM
Quote from: ctech500 This link might be of interest to you
List of devices many devices at http://www.linux-mips.org/wiki/AR7#Devices_based_on_the_Texas_Instruments_AR7
I also use a Netgear DG834GT which uses the Atheros chipset and the thing is rock solid.
24-09-2008 9:11 PM
Quote from: axisofevil
I believe that Atheros is the wireless chipset rather than the DSP chipset which is Broadcom in the Netgear GT's, I could be mistaken though.
24-09-2008 9:16 PM
24-09-2008 9:26 PM
On the base of the unit it shows the version number after the modem number.
Either v1, v2, v3 or v4 (not sure if we are on v5 yet).
Only v1 & v2 used the AR-7
24-09-2008 9:41 PM
Quote from: P The quickest way to know how safe you are on a Netgear.
Just to clarify you are referring to Netgear DG834/G and not Netgear DG834GT I know that that Sky rebadge them and use them on their ADSL2 platform
and the only issue is that Sky use their own firmware and it is well dodgy.
24-09-2008 10:37 PM
We have some of the industries most skilled and experienced tech gurus and we couldnt reach the same conclusions. From what I've read, no one else has either.
Personally, I've consigned it to the urban myth drawer.
24-09-2008 10:53 PM
Quote from: techguy ..Just wish Brown would spend it on stuff like cancer drugs to help people rather than the flaming Olympics...
Quote from: P On the base of the unit it shows the version number after the modem number.
The first three versions have an TI-AR7 Link
25-09-2008 9:34 AM
