TG585v8 Bridge Mode IPs
- Re: TG585v8 Bridge Mode IPs
19-12-2012 6:50 PM
After reading a few posts I updated the above router and put in the settings for bridge mode and connected it to a Netgear R6300. The Netgear then is asking for connection username and password (no problem there), IP address (since its static) but also for subnet mask and gateway IP. Have read various threads here and other forums mentioning different Subnet masks and gateway IPs I rang tech support and they pointed me here since they only work with basic installiations.
Any idea what subnet mask and gateway IP I should be using?
Thanks in advance,
Pete.
Thanks in advance,
Pete.
Message 1 of 5
(1,326 Views)
4 REPLIES 4
19-12-2012 7:11 PM
You need to configure the R6300 for a PPPoE connections with your PlusNet username/password. When it successfully makes the ppp connection it will get subnet mask and gateway automatically.
Message 2 of 5
(530 Views)
19-12-2012 9:33 PM
Quote from: MisterW You need to configure the R6300 for a PPPoE connections with your PlusNet username/password.
On the configuration page where it asks for the login info it asks for IP info
Message 3 of 5
(530 Views)
20-12-2012 8:23 AM
Just looked at the manual, and although it doesn't have screenshots, you need to be selecting the 'Get Dynamically from ISP' for the Internet IP settings.
Its on pages 20 & 21 of the manual I'm looking at. It should then not require you to sepcify subnet mask and gateway, they will be obtained from the ISP.
I know it sounds odd to select Dynamic when you have a static IP. In effect all that happens with a static IP is that PlusNet still assign it when the connection is made, it's just that they ALWAYS assign the same IP.
Hope that makes sense.
Message 4 of 5
(530 Views)
20-12-2012 12:57 PM
Thanks for that I'll have another go when I get home.
It'll teach me to RTFM
Message 5 of 5
(530 Views)
