TG585 v8 Firewall help
- TG585 v8 Firewall help
21-12-2010 11:15 AM
Hi all,
I have recently referred a small business to plusnet, they have received the standard Thomson router and its working as you would expect for basic internet access however they have 2 issues.
1st I have configured the Application sharing so that I can Remote desktop to the server but this has now opened up RDP for everybody to attack, I would like to remove this setting and instead configure the firewall so that only connections from my fixed IP is allowed, I can do this simply enough with my Netgear router but the Thomson firewall seems to not work (or I am configuring it wrong) I have duplicated the standard security level and added an entry:
Source Interface: WAN
Source Address: 80.229.###.### (My External IP address )
Destination Interface: LAN
Destination Address: 192.168.1.10 (Server's lan address)
Service:Any (as RDP and VNC are not listed)
then selected this security level. So this should allow all traffic from my IP to be directed to the server But I get nothing.
(I would like the option to use RDP or VNC or anything else the server is running)
2nd they are using a company called Timico for there Voip phone system (6 soft phones) using some Nortel Networks software. An engineer from the company came to connect the headsets and install the software, But its not able to connect to the server, they have tried adding entry to the firewall (and even turning the firewall off) but still can not connect. (They have an open ticket for this: 38155685)
Any hints or advice is much appreciated.
Message 1 of 5
(2,875 Views)
4 REPLIES 4
Re: TG585 v8 Firewall help
21-12-2010 11:43 AM
Message 2 of 5
(728 Views)
21-12-2010 12:09 PM
Thank Jojo unfortunately the section on the firewall consists of this:
Dave.
Quote 5.1 Firewall
Introduction
The Thomson Gateway comes with an integrated firewall. This firewall has a number of predefined levels to
allow you to adjusted the firewall to your needs.
The Firewall is disabled by default.
Changing the security level
Proceed as follows:
1 Browse to the Thomson Gateway GUI.
2 On the Toolbox menu, click Firewall.
3 The Firewall page appears. In the upper-right corner, click Configure.
4 A list with security settings with a brief description is displayed.
5 Select the security level of your choice and click Apply.
Dave.
Message 3 of 5
(728 Views)
21-12-2010 12:26 PM
Your best bet is via the CLI interface
This is the version 7 manual CLI v7 Manual
Message 4 of 5
(728 Views)
21-12-2010 12:40 PM
Thanks Oldjim, looks like an interesting little project for me over Christmas, Loads of options to tinker with....
Message 5 of 5
(728 Views)
