TG585 Vs DGN2000/ 834GT For ADSL2+
- Re: TG585 Vs DGN2000/ 834GT For ADSL2+
07-04-2009 6:51 PM
As above really , looking for some advice on what to run on the 21CN trial , 585 I have had hooked up on the PN connection todayand its seems pretty stable even now its evening time only dropping .5 on the snr , the netgear on the other had has a better web interface not like the 585 where everything is set on the CLI. What i'm after is maybe whats more compatable with the new BT 21CN hardware i know both use the broadcom chip , but in out right performance and stablility what would be best
Mark
Mark
Message 1 of 3
(1,056 Views)
2 REPLIES 2
07-04-2009 7:01 PM
See which one syncs at the best speed and then you'll have your answer
Message 2 of 3
(375 Views)
08-04-2009 10:56 PM
Depending on how low your noise margin goes, see which one gives you least errors.
That will be the deciding factor on throughput for two reasons - first, more errors - more data repetition, and second, of course If your sync rate goes down, so will the profile.
Message 3 of 3
(375 Views)
