TG582n some questions
- TG582n some questions
21-02-2013 10:53 AM
At present to do that I disconnect the router from the internet then pull out the broadband connection which isn't ideal
Is there a telnet command to increase the number of telnet sessions allowed
Re: TG582n some questions
21-02-2013 10:59 AM
Quote from: Oldjim Is there a command (web interface or telnet) which will initiate a line resync
Does this work: xdsl config adslmultimode=adsl
21-02-2013 11:07 AM
However next time I want to do a resync I will see what happens
21-02-2013 2:15 PM
Technicolor Gateway > Pick a Task > Restart my Technicolor Gateway
Zen FTTC 40/10 + Digital Voice FRITZ!Box 7530
BT technician (Retired)
21-02-2013 2:20 PM
With my old and sadly departed Netgear I could initiate a resync from DMT or Routerstats without rebooting the router
21-02-2013 2:33 PM
21-02-2013 2:39 PM
Well worth a try - thanks
21-02-2013 8:23 PM
http://npr.me.uk/telnet.html
[quote=http://npr.me.uk/telnet.html]
Force connection modulation mode to ADSL1, ADSL2 or ADSL2+ (also disable Annex M)
A useful byproduct of this command is that it causes a resync.
ie resetting the modulation to default (ie no change) can be used to force the router to perform a resync.
You can set this up in a script called up from a desktop shortcut if you want. (Scripting guide in the referenced pages).
21-02-2013 9:56 PM
21-02-2013 10:03 PM
22-02-2013 10:37 AM
22-02-2013 2:47 PM
02-03-2013 10:33 AM
Problem with Telnet sorted - it was a Routerstats and Win7 sleep mode problem which is now fixed in the latest version http://vwlowen.m3ezw.co.uk/phpbb3/viewtopic.php?f=1&t=407&sid=ab071731fd26ae12242702783da20611
02-03-2013 11:53 AM
Have you set up extra users (through the GUI)? and does this stop you from Telnetting in on another user, whilst one is active?
Haven't tried it myself yet, hope to do later.
02-03-2013 1:59 PM
I have no idea about the effect of setting up a separate user but I doubt if that would help as the telnet command failed before even putting in a username
