TG582n running at 5.5mbps on 802.11n
- TG582n running at 5.5mbps on 802.11n
- « Previous
- 1
- 2
- Next »
Re: TG582n running at 5.5mbps on 802.11n
19-05-2014 1:00 PM
Hi Chris, No, the router is already sat in a corner on its own with no other devices. My house is really small and I get really good signal strength across the whole house if I look at the network using inSSIDer.
Message 16 of 20
(595 Views)
19-05-2014 1:11 PM
Would you mind if I sent you a replacement out to see if that resolves the issue?
Message 17 of 20
(595 Views)
19-05-2014 2:00 PM
Sure. happy to try anything. I was hoping there was some config on it that I'd missed, but doesn't look like that's the case. Thanks for your help.
Message 18 of 20
(595 Views)
19-05-2014 3:13 PM
I'm interested to see how the replacement differs.
Can you keep hold of your current router so you have them both - if the replacement resolves the issue, we may want to get the current router sent to our Head Office for testing.
Message 19 of 20
(595 Views)
19-05-2014 7:04 PM
I suggest using wireshark on Linux, or Microsoft Network Monitor on Windows, to capture traffic at the wireless layer.
Message 20 of 20
(595 Views)
- « Previous
- 1
- 2
- Next »
