TG582n dropping ASDL connection
- TG582n dropping ASDL connection
Re: TG582n dropping ASDL connection
26-03-2015 10:50 AM
I will be away from about 2pm today until mid-afternoon tomorrow; will try to follow the thread while away.
My router is up 24x7
26-03-2015 11:11 AM
28-03-2015 3:50 PM
I have upgraded my older TG582b to 10.2.2.B and connected it to my network
Attached are
the last router stats page before the change-over
the router stats page on the replacement router after syncing
edit - what has happened to my SN (up) margin - now 28 and why has the up bandwidth dropped right down to 440?
Just had another drop-out and have added another page of the RouterStats
28-03-2015 4:22 PM
Might be worth looking at your ticket to see if there are any informative updates.
What's the DS and US SNRM graph looking like? - I'm expecting the US to be a flat line with the capped US speed.
28-03-2015 5:23 PM
I just added a 3rd router stats page to my last posting so I haven't repeated that.
DS and US SNRM graphs attached.
no further info on ticket
28-03-2015 5:38 PM
What does the 582n log have to say? (Don't fprget to redact the last octet of your current IP address).
28-03-2015 5:51 PM
<85> Mar 28 16:54:39 FIREWALL event (1 of 2): created rules
<85> Mar 28 16:54:39 FIREWALL event (1 of 2): modified rules
<173> Mar 28 16:54:56 xDSL linestate down
<132> Mar 28 16:55:23 PPP link down (Internet) [80.229.143.XXX]
<173> Mar 28 16:55:26 xDSL linestate down
<173> Mar 28 16:55:52 xDSL linestate up (ITU-T G.992.5; downstream: 8621 kbit/s, upstream: 440 kbit/s; output Power Down: 20.4 dBm, Up: 12.4 dBm; line Attenuation Down: 41.5 dB, Up: 23.0 dB; snr Margin Down: 6.1 dB, Up: 28.5 dB)
<38> Mar 28 16:55:54 PPP CHAP Receive challenge from rhost bras-red11.pe (Internet)
<38> Mar 28 16:55:55 PPP CHAP Receive challenge from rhost PTW-AG04 (Internet)
<38> Mar 28 16:55:55 PPP CHAP Receive success (Internet)
<85> Mar 28 16:55:55 FIREWALL event (1 of 2): deleted rules
<85> Mar 28 16:55:55 FIREWALL event (1 of 1): created rules
<85> Mar 28 16:55:55 FIREWALL event (1 of 1): modified rules
<132> Mar 28 16:55:55 PPP link up (Internet) [80.229.143.XXX]
<37> Mar 28 16:56:12 LOGIN User rs logged in on [HTTP] (from 192.168.1.65)
<102> Mar 28 16:58:33 SNTP Synchronised to server: 212.159.13.49
<37> Mar 28 17:09:02 LOGIN User rs logged in on [HTTP] (from 192.168.1.65)
<81> Mar 28 17:10:20 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 58.235.35.68 Dst ip: 80.229.143.XXX Type: Destination Unreachable Code: Port Unreacheable
<173> Mar 28 17:14:07 xDSL linestate down
<85> Mar 28 17:14:07 FIREWALL event (1 of 1): created rules
<85> Mar 28 17:14:07 FIREWALL event (1 of 1): modified rules
<173> Mar 28 17:14:24 xDSL linestate down
<173> Mar 28 17:14:55 xDSL linestate down
<132> Mar 28 17:15:00 PPP link down (Internet) [80.229.143.XXX]
<173> Mar 28 17:15:22 xDSL linestate up (ITU-T G.992.5; downstream: 8407 kbit/s, upstream: 440 kbit/s; output Power Down: 20.4 dBm, Up: 12.6 dBm; line Attenuation Down: 41.5 dB, Up: 23.0 dB; snr Margin Down: 6.1 dB, Up: 29.1 dB)
<38> Mar 28 17:15:23 PPP CHAP Receive challenge from rhost bras-red11.pe (Internet)
<38> Mar 28 17:15:23 PPP CHAP Receive challenge from rhost JUNOS (Internet)
<38> Mar 28 17:15:23 PPP CHAP Receive success (Internet)
<85> Mar 28 17:15:26 FIREWALL event (1 of 2): deleted rules
<132> Mar 28 17:15:26 PPP link up (Internet) [80.229.143.XXX]
<85> Mar 28 17:15:26 FIREWALL event (1 of 1): created rules
<85> Mar 28 17:15:26 FIREWALL event (1 of 1): modified rules
<81> Mar 28 17:23:45 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 125.31.160.110 Dst ip: 80.229.143.XXX Type: Destination Unreachable Code: Port Unreacheable
<81> Mar 28 17:31:11 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 88.84.60.247 Dst ip: 80.229.143.XXX Type: Destination Unreachable Code: Port Unreacheable
<173> Mar 28 17:38:02 xDSL linestate down
<85> Mar 28 17:38:02 FIREWALL event (1 of 1): created rules
<85> Mar 28 17:38:02 FIREWALL event (1 of 1): modified rules
<173> Mar 28 17:38:19 xDSL linestate down
<173> Mar 28 17:38:29 xDSL linestate down
<132> Mar 28 17:38:49 PPP link down (Internet) [80.229.143.XXX]
<173> Mar 28 17:38:53 xDSL linestate down
<173> Mar 28 17:39:19 xDSL linestate up (ITU-T G.992.5; downstream: 8196 kbit/s, upstream: 440 kbit/s; output Power Down: 20.4 dBm, Up: 12.7 dBm; line Attenuation Down: 41.5 dB, Up: 23.0 dB; snr Margin Down: 6.1 dB, Up: 28.8 dB)
<38> Mar 28 17:39:20 PPP CHAP Receive challenge from rhost bras-red11.pe (Internet)
<38> Mar 28 17:39:21 PPP CHAP Receive challenge from rhost JUNOS (Internet)
<38> Mar 28 17:39:21 PPRP CHAP Receive success (Internet)
<85> Mar 28 17:39:24 FIREWALL event (1 of 2): deleted rules
<132> Mar 28 17:39:24 PPP link up (Internet) [80.229.143.XXX]
<85> Mar 28 17:39:24 FIREWALL event (1 of 1): created rules
<85> Mar 28 17:39:24 FIREWALL event (1 of 1): modified rules
<81> Mar 28 17:40:37 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 176.17.123.82 Dst ip: 80.229.143.XXX Type: Destination Unreachable Code: Port Unreacheable
<81> Mar 28 17:42:43 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 186.99.90.52 Dst ip: 80.229.143.XXX Type: Destination Unreachable Code: Port Unreacheable
<37> Mar 28 17:44:16 LOGIN User rs logged in on [HTTP] (from 192.168.1.65)
{rs}
1755 JUST DROPPED FOR A 5TH TIME
28-03-2015 6:11 PM
28-03-2015 7:00 PM
Does this tell you anything
Internet
Connection Information
Link Status: IPv4 connected
IPv6 disconnected
Uptime: 0 days, 0:12:21
Data Transferred (Sent/Received) [MB/MB]: 7.15 / 14.12
Connection Settings
PVC Info (VPI.VCI): 0.38
Type: PPPoA
PPP Settings
Username: xxxxxxxx@plusdsl.net
Password: ********
Connection Mode: Always-On
TCP/IPv4 Settings
IPv4 State: Enabled
IPv4 Address: 80.229.143.xxx/32
IPv4 Default Gateway: 195.166.128.191
Primary DNS: 212.159.6.9
Secondary DNS: 212.159.6.10
TCP/IPv6 Settings
IPv6 State: Disabled
Stateless Address Autoconfiguration: Disabled
IPv6 Address: -
IPv6 Default Gateway: -
Local Interface ID: -
Remote Interface ID: -
IAPD Prefix: -
DNS Server 1: -
there were 7 drop-outs between 17:15 and 18:17
28-03-2015 7:45 PM
29-03-2015 6:34 PM
With 7 drops in the space of that hour yesterday, if the Quiet Line Test is showing nothing, I did wonder if it's some sort of REIN issue. I don't suppose there was any particular electrical/electronic activity during that time that you might be aware of?
However the way the DS SNRM was behaving just before each of the drops showing on the graph you posted look typical of a bad connection.
I was hoping Tony might have taken a quick look yesterday after you initially posted, but he finished at 6.
29-03-2015 7:22 PM
I was out all day until now and found that there have been more drop-outs during that time. My laptop was closed and I have no router stats to look at. Also I cannot cast any light on possible REIN. I will try to follow up any further drop-outs that I notice.
I have extracted ppp link down/ups from the log from around 22:00 yesterday up to now. I make it 13 drop-outs in that period. I apologise in advance for the length of this log.
TELNET LOG [extracts]
<102> Mar 28 21:59:19 SNTP Synchronised to server: 212.159.13.50
<84> Mar 28 22:00:32 IDS proto parser : tcp null port (1 of 1) : 113.108.21.16 80.229.143.xxx 40 50 TCP 12200->0 [S.....] seq 1006459802 ack 0 win 8192
<132> Mar 28 22:01:11 PPP link down (Internet) [80.229.143.xxx]
<85> Mar 28 22:01:11 FIREWALL event (1 of 2): created rules
<85> Mar 28 22:01:11 FIREWALL event (1 of 2): modified rules
<38> Mar 28 22:01:25 PPP CHAP Receive challenge from rhost bras-red11.pe (Internet)
<38> Mar 28 22:01:25 PPP CHAP Receive challenge from rhost JUNOS (Internet)
<38> Mar 28 22:01:25 PPP CHAP Receive success (Internet)
<85> Mar 28 22:01:28 FIREWALL event (1 of 2): deleted rules
<132> Mar 28 22:01:28 PPP link up (Internet) [80.229.143.xxx]
-------------------------------------------------snip--------------------------------------------
<132> Mar 28 22:19:39 PPP link down (Internet) [80.229.143.xxx]
<85> Mar 28 22:19:39 FIREWALL event (1 of 2): created rules
<85> Mar 28 22:19:39 FIREWALL event (1 of 2): modified rules
<38> Mar 28 22:19:53 PPP CHAP Receive challenge from rhost bras-red11.pe (Internet)
<38> Mar 28 22:19:53 PPP CHAP Receive challenge from rhost JUNOS (Internet)
<38> Mar 28 22:19:53 PPP CHAP Receive success (Internet)
<85> Mar 28 22:19:57 FIREWALL event (1 of 2): deleted rules
<132> Mar 28 22:19:57 PPP link up (Internet) [80.229.143.xxx]
<132> Mar 29 03:11:11 PPP link down (Internet) [80.229.143.xxx]
<85> Mar 29 03:11:11 FIREWALL event (1 of 2): created rules
<85> Mar 29 03:11:11 FIREWALL event (1 of 2): modified rules
<38> Mar 29 03:11:24 PPP CHAP Receive challenge from rhost bras-red11.pe (Internet)
<38> Mar 29 03:11:25 PPP CHAP Receive challenge from rhost JUNOS (Internet)
<38> Mar 29 03:11:25 PPP CHAP Receive success (Internet)
<85> Mar 29 03:11:25 FIREWALL event (1 of 2): deleted rules
<132> Mar 29 03:11:25 PPP link up (Internet) [80.229.143.xxx]
<102> Mar 29 03:59:20 SNTP Synchronised to server: 212.159.13.49
<132> Mar 29 04:10:28 PPP link down (Internet) [80.229.143.xxx]
<85> Mar 29 04:10:28 FIREWALL event (1 of 2): created rules
<85> Mar 29 04:10:28 FIREWALL event (1 of 2): modified rules
<38> Mar 29 04:10:41 PPP CHAP Receive challenge from rhost bras-red11.pe (Internet)
<38> Mar 29 04:10:41 PPP CHAP Receive challenge from rhost JUNOS (Internet)
<38> Mar 29 04:10:42 PPP CHAP Receive success (Internet)
<85> Mar 29 04:10:48 FIREWALL event (1 of 2): deleted rules
<132> Mar 29 04:10:48 PPP link up (Internet) [80.229.143.xxx]
<132> Mar 29 04:11:02 PPP link down (Internet) [80.229.143.xxx]
<38> Mar 29 04:11:15 PPP CHAP Receive challenge from rhost bras-red11.pe (Internet)
<38> Mar 29 04:11:16 PPP CHAP Receive challenge from rhost JUNOS (Internet)
<38> Mar 29 04:11:16 PPP CHAP Receive success (Internet)
<132> Mar 29 04:11:19 PPP link up (Internet) [80.229.143.xxx]
<81> Mar 29 04:57:13 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 125.69.182.105 Dst ip: 80.229.143.xxxType: Destination Unreachable Code: Port Unreacheable
<102> Mar 29 04:59:20 SNTP Synchronised to server: 212.159.6.10
-------------------------------snip---------------------------------------------------
<132> Mar 29 09:02:37 PPP link down (Internet) [80.229.143.xxx]
<85> Mar 29 09:02:37 FIREWALL event (1 of 4): created rules
<85> Mar 29 09:02:37 FIREWALL event (1 of 4): modified rules
<38> Mar 29 09:02:50 PPP CHAP Receive challenge from rhost bras-red11.pe (Internet)
<38> Mar 29 09:02:50 PPP CHAP Receive challenge from rhost PCL-AG07 (Internet)
<38> Mar 29 09:02:51 PPP CHAP Receive success (Internet)
<132> Mar 29 09:02:54 PPP link up (Internet) [80.229.143.xxx]
----------------------------------------------snip------------------------------------------------------------
<132> Mar 29 10:13:04 PPP link down (Internet) [80.229.143.xxx]
<85> Mar 29 10:13:04 FIREWALL event (1 of 2): created rules
<85> Mar 29 10:13:04 FIREWALL event (1 of 2): modified rules
<38> Mar 29 10:13:18 PPP CHAP Receive challenge from rhost bras-red11.pe (Internet)
<38> Mar 29 10:13:18 PPP CHAP Receive challenge from rhost JUNOS (Internet)
<38> Mar 29 10:13:18 PPP CHAP Receive success (Internet)
<85> Mar 29 10:13:22 FIREWALL event (1 of 2): deleted rules
<132> Mar 29 10:13:22 PPP link up (Internet) [80.229.143.xxx]
----------------------------------------------------snip-----------------------------------
<132> Mar 29 10:37:34 PPP link down (Internet) [80.229.143.xxx]
<85> Mar 29 10:37:34 FIREWALL event (1 of 2): created rules
<85> Mar 29 10:37:34 FIREWALL event (1 of 2): modified rules
<38> Mar 29 10:37:48 PPP CHAP Receive challenge from rhost bras-red11.pe (Internet)
<38> Mar 29 10:37:48 PPP CHAP Receive challenge from rhost JUNOS (Internet)
<38> Mar 29 10:37:49 PPP CHAP Receive success (Internet)
<85> Mar 29 10:37:49 FIREWALL event (1 of 2): deleted rules
<132> Mar 29 10:37:49 PPP link up (Internet) [80.229.143.xxx]
<132> Mar 29 10:49:11 PPP link down (Internet) [80.229.143.xxx]
<85> Mar 29 10:49:11 FIREWALL event (1 of 2): created rules
<85> Mar 29 10:49:11 FIREWALL event (1 of 2): modified rules
<38> Mar 29 10:49:25 PPP CHAP Receive challenge from rhost bras-red11.pe (Internet)
<38> Mar 29 10:49:25 PPP CHAP Receive challenge from rhost PCL-AG02 (Internet)
<38> Mar 29 10:49:25 PPP CHAP Receive success (Internet)
<85> Mar 29 10:49:26 FIREWALL event (1 of 2): deleted rules
<132> Mar 29 10:49:26 PPP link up (Internet) [80.229.143.xxx]
<102> Mar 29 10:58:38 SNTP Synchronised again to server: 212.159.6.9
<132> Mar 29 12:36:07 PPP link down (Internet) [80.229.143.xxx]
<85> Mar 29 12:36:08 FIREWALL event (1 of 2): created rules
<85> Mar 29 12:36:08 FIREWALL event (1 of 2): modified rules
<38> Mar 29 12:36:21 PPP CHAP Receive challenge from rhost bras-red11.pe (Internet)
<38> Mar 29 12:36:21 PPP CHAP Receive challenge from rhost JUNOS (Internet)
<38> Mar 29 12:36:21 PPP CHAP Receive success (Internet)
<85> Mar 29 12:36:25 FIREWALL event (1 of 2): deleted rules
<132> Mar 29 12:36:25 PPP link up (Internet) [80.229.143.xxx]
--------------------------------------------------------snip------------------------------------
<132> Mar 29 12:42:43 PPP link down (Internet) [80.229.143.xxx]
<85> Mar 29 12:42:43 FIREWALL event (1 of 2): created rules
<85> Mar 29 12:42:43 FIREWALL event (1 of 2): modified rules
<38> Mar 29 12:42:56 PPP CHAP Receive challenge from rhost bras-red11.pe (Internet)
<38> Mar 29 12:42:57 PPP CHAP Receive challenge from rhost JUNOS (Internet)
<38> Mar 29 12:42:57 PPP CHAP Receive success (Internet)
<85> Mar 29 12:42:57 FIREWALL event (1 of 2): deleted rules
<132> Mar 29 12:42:57 PPP link up (Internet) [80.229.143.xxx]
<102> Mar 29 12:58:41 SNTP Synchronised to server: 212.159.13.49
<132> Mar 29 17:16:56 PPP link down (Internet) [80.229.143.xxx]
<85> Mar 29 17:16:56 FIREWALL event (1 of 2): created rules
<85> Mar 29 17:16:56 FIREWALL event (1 of 2): modified rules
<38> Mar 29 17:17:09 PPP CHAP Receive challenge from rhost bras-red11.pe (Internet)
<38> Mar 29 17:17:10 PPP CHAP Receive challenge from rhost JUNOS (Internet)
<38> Mar 29 17:17:10 PPP CHAP Receive success (Internet)
<85> Mar 29 17:17:10 FIREWALL event (1 of 2): deleted rules
<132> Mar 29 17:17:10 PPP link up (Internet) [80.229.143.xxx]
<132> Mar 29 17:34:54 PPP link down (Internet) [80.229.143.xxx]
<85> Mar 29 17:34:54 FIREWALL event (1 of 2): created rules
<85> Mar 29 17:34:54 FIREWALL event (1 of 2): modified rules
<38> Mar 29 17:35:08 PPP CHAP Receive challenge from rhost bras-red11.pe (Internet)
<38> Mar 29 17:35:11 PPP CHAP Receive challenge from rhost PTN-AG04 (Internet)
<38> Mar 29 17:35:11 PPP CHAP Receive success (Internet)
<85> Mar 29 17:35:11 FIREWALL event (1 of 2): deleted rules
<132> Mar 29 17:35:12 PPP link up (Internet) [80.229.143.xxx]
<37> Mar 29 17:54:18 LOGIN User rs logged in on TELNET (192.168.1.65)
<102> Mar 29 17:58:44 SNTP Synchronised again to server: 212.159.6.9
<37> Mar 29 17:59:04 LOGIN User rs logged in on [HTTP] (from 192.168.1.65)
<81> Mar 29 18:12:24 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 172.218.91.115 Dst ip: 80.229.143.xxxType: Destination Unreachable Code: Host Unreacheable
<37> Mar 29 18:28:06 LOGIN User rs logged in on [HTTP] (from 192.168.1.65)
<14> Mar 29 18:31:59 CONFIGURATION mbus atomic sync successful
<14> Mar 29 18:32:02 CONFIGURATION mbus igd sync successfull
<14> Mar 29 18:34:58 CONFIGURATION mbus atomic sync successful
<14> Mar 29 18:35:01 CONFIGURATION mbus igd sync successfull
{rs}
29-03-2015 8:19 PM
Did you reboot the 582n around 1915 yesterday?
Don't forget that often the entries in the log leading upto the xDSL linestate down - especially "Kernel" ones can be very revealing.
29-03-2015 9:04 PM
I have selected a section of the telnet log covering both 19:15 and 18:15 which might be the relevant time taking the overnight clock change into consideration.
I will now check the log to find the PPP drops without xDSL.
If you would like to see the unabridged log please let me know
<85> Mar 28 17:53:24 FIREWALL event (1 of 1): created rules
<85> Mar 28 17:53:24 FIREWALL event (1 of 1): modified rules
<173> Mar 28 17:55:00 xDSL linestate down
<85> Mar 28 17:55:00 FIREWALL event (1 of 1): created rules
<85> Mar 28 17:55:00 FIREWALL event (1 of 1): modified rules
<173> Mar 28 17:55:18 xDSL linestate down
<132> Mar 28 17:55:44 PPP link down (Internet) [80.229.143.xxx]
<173> Mar 28 17:55:48 xDSL linestate down
<173> Mar 28 17:56:14 xDSL linestate up (ITU-T G.992.5; downstream: 7785 kbit/s, upstream: 440 kbit/s; output Power Down: 20.4 dBm, Up: 12.3 dBm; line Attenuation Down: 41.5 dB, Up: 23.0 dB; snr Margin Down: 6.1 dB, Up: 28.6 dB)
<38> Mar 28 17:56:18 PPP CHAP Receive challenge from rhost bras-red11.pe (Internet)
<38> Mar 28 17:56:19 PPP CHAP Receive challenge from rhost JUNOS (Internet)
<38> Mar 28 17:56:19 PPP CHAP Receive success (Internet)
<85> Mar 28 17:56:22 FIREWALL event (1 of 2): deleted rules
<132> Mar 28 17:56:22 PPP link up (Internet) [80.229.143.xxx]
<85> Mar 28 17:56:22 FIREWALL event (1 of 1): created rules
<85> Mar 28 17:56:22 FIREWALL event (1 of 1): modified rules
<173> Mar 28 17:58:15 xDSL linestate down
<85> Mar 28 17:58:15 FIREWALL event (1 of 1): created rules
<85> Mar 28 17:58:15 FIREWALL event (1 of 1): modified rules
<173> Mar 28 17:58:33 xDSL linestate down
<132> Mar 28 17:58:59 PPP link down (Internet) [80.229.143.xxx]
<173> Mar 28 17:59:03 xDSL linestate down
<100> Mar 28 17:59:18 SNTP Unable to contact server: 198.18.1.118
<173> Mar 28 17:59:29 xDSL linestate up (ITU-T G.992.5; downstream: 7926 kbit/s, upstream: 440 kbit/s; output Power Down: 20.4 dBm, Up: 12.6 dBm; line Attenuation Down: 41.5 dB, Up: 23.0 dB; snr Margin Down: 6.1 dB, Up: 29.0 dB)
<38> Mar 28 17:59:31 PPP CHAP Receive challenge from rhost bras-red11.pe (Internet)
<38> Mar 28 17:59:31 PPP CHAP Receive challenge from rhost JUNOS (Internet)
<38> Mar 28 17:59:34 PPP CHAP Receive success (Internet)
<85> Mar 28 17:59:34 FIREWALL event (1 of 2): deleted rules
<132> Mar 28 17:59:34 PPP link up (Internet) [80.229.143.xxx]
<85> Mar 28 17:59:34 FIREWALL event (1 of 1): created rules
<85> Mar 28 17:59:34 FIREWALL event (1 of 1): modified rules
<81> Mar 28 18:04:36 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 200.169.69.114 Dst ip: 80.229.143.xxx Type: Destination Unreachable Code: Port Unreacheable
<173> Mar 28 18:12:47 xDSL linestate down
<85> Mar 28 18:12:47 FIREWALL event (1 of 1): created rules
<85> Mar 28 18:12:47 FIREWALL event (1 of 1): modified rules
<173> Mar 28 18:13:04 xDSL linestate down
<173> Mar 28 18:13:34 xDSL linestate down
<132> Mar 28 18:13:35 PPP link down (Internet) [80.229.143.xxx]
<173> Mar 28 18:14:00 xDSL linestate up (ITU-T G.992.5; downstream: 7833 kbit/s, upstream: 440 kbit/s; output Power Down: 20.4 dBm, Up: 12.9 dBm; line Attenuation Down: 41.0 dB, Up: 23.0 dB; snr Margin Down: 6.1 dB, Up: 29.7 dB)
<38> Mar 28 18:14:03 PPP CHAP Receive challenge from rhost bras-red11.pe (Internet)
<38> Mar 28 18:14:04 PPP CHAP Receive challenge from rhost JUNOS (Internet)
<38> Mar 28 18:14:04 PPP CHAP Receive success (Internet)
<85> Mar 28 18:14:08 FIREWALL event (1 of 2): deleted rules
<132> Mar 28 18:14:08 PPP link up (Internet) [80.229.143.xxx]
<85> Mar 28 18:14:08 FIREWALL event (1 of 1): created rules
<85> Mar 28 18:14:08 FIREWALL event (1 of 1): modified rules
<173> Mar 28 18:15:36 xDSL linestate down
<85> Mar 28 18:15:36 FIREWALL event (1 of 1): created rules
<85> Mar 28 18:15:36 FIREWALL event (1 of 1): modified rules
<173> Mar 28 18:15:53 xDSL linestate down
<173> Mar 28 18:16:23 xDSL linestate down
<132> Mar 28 18:16:35 PPP link down (Internet) [80.229.143.xxx]
<173> Mar 28 18:16:49 xDSL linestate up (ITU-T G.992.5; downstream: 7593 kbit/s, upstream: 440 kbit/s; output Power Down: 20.4 dBm, Up: 12.6 dBm; line Attenuation Down: 41.5 dB, Up: 23.0 dB; snr Margin Down: 6.1 dB, Up: 28.9 dB)
<38> Mar 28 18:16:54 PPP CHAP Receive challenge from rhost bras-red11.pe (Internet)
<38> Mar 28 18:16:54 PPP CHAP Receive challenge from rhost JUNOS (Internet)
<38> Mar 28 18:16:55 PPP CHAP Receive success (Internet)
<85> Mar 28 18:16:55 FIREWALL event (1 of 2): deleted rules
<85> Mar 28 18:16:55 FIREWALL event (1 of 1): created rules
<85> Mar 28 18:16:55 FIREWALL event (1 of 1): modified rules
<132> Mar 28 18:16:55 PPP link up (Internet) [80.229.143.xxx]
<81> Mar 28 18:31:53 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 121.17.138.130 Dst ip: 80.229.143.xxx Type: Destination Unreachable Code: Port Unreacheable
<81> Mar 28 18:40:54 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 200.165.72.21 Dst ip: 80.229.143.xxx Type: Destination Unreachable Code: Host Unreacheable
<132> Mar 28 18:41:43 PPP link down (Internet) [80.229.143.xxx]
<85> Mar 28 18:41:43 FIREWALL event (1 of 1): created rules
<85> Mar 28 18:41:43 FIREWALL event (1 of 1): modified rules
<38> Mar 28 18:41:57 PPP CHAP Receive challenge from rhost bras-red11.pe (Internet)
<38> Mar 28 18:41:57 PPP CHAP Receive challenge from rhost PTN-AG02 (Internet)
<38> Mar 28 18:41:57 PPP CHAP Receive success (Internet)
<85> Mar 28 18:41:58 FIREWALL event (1 of 2): deleted rules
<132> Mar 28 18:41:58 PPP link up (Internet) [80.229.143.xxx]
<37> Mar 28 18:48:50 LOGIN User admin logged in on [HTTP] (from 192.168.1.65)
<81> Mar 28 18:53:50 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 109.83.237.133 Dst ip: 80.229.143.xxx Type: Destination Unreachable Code: Port Unreacheable
<102> Mar 28 18:59:18 SNTP Synchronised to server: 212.159.6.10
<81> Mar 28 19:14:15 FIREWALL icmp check (1 of 2): Protocol: ICMP Src ip: 124.133.146.128 Dst ip: 80.229.143.xxx Type: Destination Unreachable Code: Port Unreacheable
<37> Mar 28 19:17:47 LOGIN User rs logged in on [HTTP] (from 192.168.1.65)
<81> Mar 28 19:27:26 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 158.39.29.69 Dst ip: 80.229.143.xxx Type: Destination Unreachable Code: Communication Administratively Prohibited
<81> Mar 28 19:43:31 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 123.248.166.13 Dst ip: 80.229.143.xxx Type: Destination Unreachable Code: Port Unreacheable
<37> Mar 28 19:50:27 LOGIN User admin logged in on [HTTP] (from 192.168.1.65)
<102> Mar 28 19:59:19 SNTP Synchronised again to server: 212.159.6.10
<81> Mar 28 20:06:13 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 58.246.230.210 Dst ip: 80.229.143.xxx Type: Destination Unreachable Code: Port Unreacheable
<81> Mar 28 20:09:49 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 24.30.174.82 Dst ip: 80.229.143.xxx Type: Destination Unreachable Code: Host Unreacheable
<37> Mar 28 20:22:35 LOGIN User rs logged in on [HTTP] (from 192.168.1.65)
<81> Mar 28 20:34:07 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 222.139.75.34 Dst ip: 80.229.143.xxx Type: Destination Unreachable Code: Port Unreacheable
<81> Mar 28 20:36:19 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 115.50.164.80 Dst ip: 80.229.143.xxx Type: Destination Unreachable Code: Port Unreacheable
<81> Mar 28 20:45:57 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 179.32.163.139 Dst ip: 80.229.143.xxx Type: Destination Unreachable Code: Port Unreacheable
<102> Mar 28 20:59:19 SNTP Synchronised to server: 212.159.13.49
29-03-2015 9:53 PM
I have examined the entire current telnet log starting at Mar 28 16:14:09 - I have attached a colour-coded version
The first 7 drops were all PPP with xDSL down; the last of these finished at Mar 28 18:16:55
Another 13 from Mar 28 18:41:43 up to Mar 29 20:31:11 were all PPP down only.
