TG582n Access Control configuration via Telnet?
Robz
Hi Folks, is it possible to adjust the settings illustrated below via the telnet interface.
I have searched the routers CLI (telnet Command Line Interface) manual  here for the likely commands with no luck yet.
2 REPLIES 2
Aspiring Hero
Fixes: 74
Re: TG582n Access Control configuration via Telnet?
Hi @Robz
This is a very old device and some of the useful information has been removed. A valuable source of information was found at http://npr.me.uk this site has closed.
However all is not lost you can retrieve the pages from  https://web.archive.org
Search for http://npr.me.uk/accesscontrol.html  important you go back to 2012.
You can export the routers config file and it is a text file, the section you are looking for is [tod.ini] Suggest using notepad++ to view it
Hope this helps
Dan.
BTW this really should have been posted in 'My Router'
Robz
@Dan_the_Van wrote:
Hi @Robz
Hope this helps
Dan.
Great post, thank you, I shall give it a whirl . . . .
