TG582N - Network File Server
- Re: TG582N - Network File Server
09-03-2013 9:23 PM
Hi, on reading the manual for the TG582n it indicates that under content sharing that the network file server allows devices in the same Workgroup to have read + write access to a shared external disk attached via the USB port of the TG582n. I have set the router up and disk as per the instructions and whilst I can read any file on the disk(in the media folder), I can't WRITE to the disk. Can anybody help? The disk has been formatted as FAT32.
thanks
Pete
thanks
Pete
Message 1 of 7
(1,980 Views)
6 REPLIES 6
09-03-2013 9:41 PM
It may be the disks needs more power than the routers USB can supply.
Do you have a powered USB hub you could use between the router and HDD.
Message 2 of 7
(691 Views)
04-04-2013 9:17 AM
I hardly think that is relevant to a disk write problem. If there's enough power to move the disk head to perform a read then there is certainly enough for it to perform a write. As it happens the disk is in an external caddy with it's own independent power supply.
Any sensible suggestions please?
Message 3 of 7
(691 Views)
04-04-2013 9:44 AM
Quote from: peterrushworth As it happens the disk is in an external caddy with it's own independent power supply.
Without the benefit of a crystal ball that was a sensible suggestion.
Message 4 of 7
(691 Views)
05-04-2013 9:41 AM
Quote If there's enough power to move the disk head to perform a read then there is certainly enough for it to perform a write.
Actually in my experience of having problems with portable drives a write will draw a little more power than a read of the disk.
What is the drive formatted to? I believe the TG582N may have a problem reading from NTFS.
Adam
Message 5 of 7
(691 Views)
05-04-2013 9:50 AM
Yeah, the router won't do NTFS due to needing to pay M$ lots of money for the license
Kelly Dorset
Ex-Broadband Service Manager
Message 6 of 7
(691 Views)
05-04-2013 9:54 AM
Quote from: peterrushworth The disk has been formatted as FAT32.
Message 7 of 7
(691 Views)
