TG582 - Is it possible to configure it to wireless 'G' only
- TG582 - Is it possible to configure it to wireless...
06-12-2012 11:45 AM
Just swapped to this from a separate Netgear DG834v1 (no wireless) and a Netgear WG602v2 WAP. I'm finding the signal at the far end of the bungalow drops out a bit where it was OK with the Netgear. As I only use G I thought I'd see if putting the TG in to G only helped, but I can't see where to change it.
Message 1 of 6
(1,546 Views)
5 REPLIES 5
Re: TG582 - Is it possible to configure it to wireless 'G' only
06-12-2012 12:14 PM
Don't know if the UI on the TG582 is the same but on the TG585 the wireless configuration page is accessed by clicking Home Network on the left-hand menu, then WLAN in the central list and finally Configure tucked away in the top-right corner.
The TG585 has an Interface Type drop-down for selecting what's required.
Click Apply at the bottom if you change anything.
David
Message 2 of 6
(806 Views)
06-12-2012 1:10 PM
This is what I see. Am I missing the obvious?
Message 3 of 6
(806 Views)
06-12-2012 2:43 PM
Jelv, I don't believe you can set it from the UI.
You can change it from the Telnet CLI using the 'wireless radio interop' command see here http://community.plus.net/forum/?topic=105166.msg896590
Not sure whether it will accept g only or just b/g
Edit: dont forget the 'saveall' to make it permanent
Message 4 of 6
(806 Views)
06-12-2012 2:49 PM
{admin}=>:wireless radio interop=802.11g
parameter interop has wrong setting.
Bad value for parameter 'interop 802.11g'
Could not parse command
Unknown command.
{admin}=>:wireless radio interop=802.11b/g
{admin}=>
Message 5 of 6
(805 Views)
06-12-2012 3:01 PM
I've just checked with Phil and G only isn't an option.
Message 6 of 6
(806 Views)
