TBB vs Pingtest.net
shure
TBB vs Pingtest.net
Just wondered why there would be a discrepancy between the results from the above two tests.  According to TBB I've had a pretty stable connection all day while pingtest.net shows me losing packets left right and centre since around 14:55 today:
and it's been going in a similar vein ever since then,
vs:
12 REPLIES 12
Re: TBB vs Pingtest.net
Are you running the pingtest.net over wired or wireless (or even powerline)?
shure
tests are only run on fixed connection, i.e. direct Ethernet cable between router and PC
edit: both tests were run from the same PC, which is why I can't understand the discrepancy.  Even now when I look at the TBB graph it says I've had a smooth run all afternoon which hasn't been my experience!
Fixes: 91
That's quite a big discrepancy, how do speed tests on speedtest.net and TBB compare?
 Adam Walker
shure
just to underline the point, here's the latest from pingtest.net, while TBB looks like I've drawn a horizontal line with a ruler:
I'll check speedtest.net now
shure
speedtest.net has me at a whopping 1MB download speed, also with exceptionally high ping:
and from TBB:
http://www.thinkbroadband.com/speedtest/results/id/135896021353338914699.html
sorry, can't seem to paste picture from thereSad
but it's 2.6MB up and 0.2MB down
A few things...
Do the IP addresses http://www.thinkbroadband.com/ping and http://www.thinkbroadband.com/ip.html match?
If you go Start > Run > cmd and type ping 80.249.99.164 -n 100 then post the summary at the end here.
Also do ping x.x.x.x  -n 100 where x.x.x.x is your router IP (e.g. 192.168.1.1)
Fixes: 91
I'm wondering if the fact that both sites will be using servers in different locations could possibly affect that? If they did I'm not sure if would be to that extent for either ping or speedtests though. Try http://www.speedtester.bt.com and see what that says.
Adam
 Adam Walker
Fixes: 118
TBB is checking the connection from the Internet to your router, pingtest.net and speedtest.net are testing all the way back to your machine. That kinda points towards a problem between machine and router. The results of the extended ping to the router would be interesting to see.
Fixes: 10
I'd have thought pathping would be a better diagnostic:
C:\Users\John>pathping 80.249.99.164
Tracing route to pingbox1.thinkbroadband.com [80.249.99.164]
over a maximum of 30 hops:
  0  Elvin06 [192.168.1.6]
  1  tg582 [192.168.1.254]
  2  lo0-central10.ptw-ag01.plus.net [195.166.128.195]
  3  link9-central10.ptw-gw01.plus.net [84.93.248.16]
  4  xe-0-2-0.ptw-cr01.plus.net [212.159.1.16]
  5  linx-gw1.thn.ncuk.net [195.66.224.240]
  6  gi0-24-10-star1.core-rs2.thdo.ncuk.net [80.249.97.9]
  7  pingbox1.thinkbroadband.com [80.249.99.164]
Computing statistics for 175 seconds...
            Source to Here  This Node/Link
Hop  RTT    Lost/Sent = Pct  Lost/Sent = Pct  Address
                                0/ 100 =  0%  |
  1    0ms    0/ 100 =  0%    0/ 100 =  0%  tg582 [192.168.1.254]
                                0/ 100 =  0%  |
  2  21ms    0/ 100 =  0%    0/ 100 =  0%  lo0-central10.ptw-ag01.plus.net [195.166.128.195]
                                0/ 100 =  0%  |
  3  20ms    0/ 100 =  0%    0/ 100 =  0%  link9-central10.ptw-gw01.plus.net [84.93.248.16]
                                0/ 100 =  0%  |
  4  18ms    0/ 100 =  0%    0/ 100 =  0%  xe-0-2-0.ptw-cr01.plus.net [212.159.1.16]
                                0/ 100 =  0%  |
  5  17ms    0/ 100 =  0%    0/ 100 =  0%  linx-gw1.thn.ncuk.net [195.66.224.240]
                                0/ 100 =  0%  |
  6  17ms    0/ 100 =  0%    0/ 100 =  0%  gi0-24-10-star1.core-rs2.thdo.ncuk.net [80.249.97.9]
                                0/ 100 =  0%  |
  7  14ms    0/ 100 =  0%    0/ 100 =  0%  pingbox1.thinkbroadband.com [80.249.99.164]
Trace complete.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
shure
Hi all,
many thanks for the suggestions and apologies for the delay in replying but it seems to have stabilised over the last three days, ever since I changed my Technicolor router for my old Netgear one.  I'm getting more consistency now and no huge variations
Glad to see that it's improved for you.
Let us know if anything changes.
