TBB again more spikes
- Re: TBB again more spikes
29-12-2013 6:49 PM
Only seems to be mine and mikehiow that show the spikes today at the same times from http://community.plus.net/ping-graphs/ at roughly 1pm 1.20pm 3.30pm 6.20pm, my router logs show no dropped PPP or sync, phone is crystal clear, currently on ptw-ag01
edit: Strat's as well, opera failed to load his graph first time
FTTP 500 regrade from Tues 28th November
Message 1 of 6
(1,765 Views)
5 REPLIES 5
30-12-2013 4:57 PM
I did a clean router reboot this morning and now on pcl-ag02 with no repeats since, but see that both Strat and mikehiow both still get them so looking like ptw-ag01 is at fault
Message 2 of 6
(670 Views)
30-12-2013 7:15 PM
Changed Gateway...now on pcl-ag03.
Message 3 of 6
(670 Views)
30-12-2013 7:44 PM
Receiving stupid pings with ag6.
This is just rubbish, even if it's peak time (7:40PM) I shouldn't be getting ping times of 1000.
Yes, I've rebooted the router, and I am the only one on my own network not downloading anything.
The strange thing is that ping is normal for about 2-3minutes after a connection refresh and then it goes to stupid.
I'm seriously getting fed up with this,
Edit: Another trace from google:
Tracing route to bbc.com [212.58.253.67]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms home.gateway.home.gateway [192.168.1.254]
2 870 ms 895 ms 742 ms lo0-central10.pcl-ag06.plus.net [195.166.128.187
3 574 ms 499 ms 429 ms link-a-central10.pcl-gw01.plus.net [212.159.2.18
0]
4 579 ms 863 ms 936 ms xe-10-3-0.pcl-cr01.plus.net [212.159.0.212]
5 923 ms 891 ms 929 ms ae1.ptw-cr01.plus.net [195.166.129.0]
6 1114 ms 1189 ms 1177 ms 212.58.239.6
7 * * * Request timed out.
8 910 ms 904 ms 968 ms ae0.er01.cwwtf.bbc.co.uk [132.185.254.93]
9 543 ms 684 ms 767 ms 132.185.255.156
10 * 537 ms 439 ms www-vip.cwwtf.bbc.co.uk [212.58.253.67]
Tracing route to google.com [173.194.34.131]
2 316 ms 430 ms 381 ms lo0-central10.pcl-ag06.plus.net [195.166.128.187
3 416 ms 391 ms 426 ms link-a-central10.pcl-gw01.plus.net [212.159.2.18
0]
4 444 ms 477 ms 515 ms xe-10-3-0.pcl-cr01.plus.net [212.159.0.212]
5 558 ms 596 ms 680 ms ae1.ptw-cr01.plus.net [195.166.129.0]
6 1105 ms * 522 ms 72.14.222.97
7 571 ms 592 ms 463 ms 209.85.240.63
8 241 ms 307 ms 305 ms 209.85.253.115
9 204 ms 231 ms 261 ms lhr14s21-in-f3.1e100.net [173.194.34.131]
Trace complete.
Message 4 of 6
(670 Views)
31-12-2013 9:34 AM
Nothing obvious on the graphing from here. Gus, do you have a snapshot of your TBB graph from when you were having this issue? Also was it causing any problems at all?
Message 5 of 6
(670 Views)
31-12-2013 2:00 PM
29th Dec
30th
I did a reboot on 30th at 8am as I hadn't in a while and to see if it was the gateway at fault, after it no more spikes. But both Strat and Mikehiow showed more at the same times on 30th, so that said to me they were on the same gateway. Mikehiow still showing them for yesterday at 5pm and 9.20ish pm.
As for if they affected my connection, during some of them I was watching IPlayer or channel4 player and did have the streams stall, which is why I checked my graph initially.
30th
Message 6 of 6
(670 Views)
