Synch speed shows OK, actual about 15 times less
- Re: Synch speed shows OK, actual about 15 times le...
18-06-2014 2:57 PM
Title says it. Speeds seemed very low earlier. Router showed low. Rebooted router - improved. Now again real speeds very low though router shows OK ever after rebooting router and then PC then router again. Can anyone help please? Same if tested from a mobile phone - real speed very slow.
Uptime: 0 days, 0:06:15
DSL Type: ITU-T G.992.3
Bandwidth (Up/Down) [kbps/kbps]: 999 / 6.479
Data Transferred (Sent/Received) [MB/MB]: 4,83 / 8,03
Output Power (Up/Down) [dBm]: 12,7 / 0,0
Line Attenuation (Up/Down) [dB]: 29,2 / 48,0
SN Margin (Up/Down) [dB]: 5,9 / 6,1
Loss of Link (Remote): -
Error Seconds (Local/Remote): 6 / 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 7 / 207
HEC Errors (Up/Down): 4 / 274
http://www.speedtest.net/my-result/3564032080
and now
http://www.speedtest.net/my-result/3571026375
and now
Message 1 of 3
(519 Views)
2 REPLIES 2
Re: Synch speed shows OK, actual about 15 times less
18-06-2014 3:44 PM
Message 2 of 3
(362 Views)
18-06-2014 3:49 PM
Ah your reply came through as I was typing - now OK thanks.
Uptime: 0 days, 0:04:53
Bandwidth (Up/Down) [kbps/kbps]: 975 / 6.460
Data Transferred (Sent/Received) [MB/MB]: 1,83 / 11,42
Output Power (Up/Down) [dBm]: 12,6 / 0,0
Line Attenuation (Up/Down) [dB]: 29,2 / 47,5
SN Margin (Up/Down) [dB]: 6,5 / 6,1
Error Seconds (Local/Remote): 3 / 0
CRC Errors (Up/Down): 12 / 3
HEC Errors (Up/Down): 2 / 5
And actual speed:
http://www.speedtest.net/my-result/3571135376
And actual speed:
Message 3 of 3
(362 Views)
