Sync speed same after fibre install
- Re: Sync speed same after fibre install
16-05-2014 1:40 PM
Hi
I have had my fibre installed today however i'm still sync'd at 6.5mb (my adsl speed)please can you check my profile. I should be getting close to 80mb
Many Thanks
Nokk
Many Thanks
Nokk
Message 1 of 6
(819 Views)
5 REPLIES 5
16-05-2014 2:03 PM
Hi Nokk,
Really sorry about that. Could you restart your router and see if the profile change I've made has made a difference for you?
Message 2 of 6
(591 Views)
16-05-2014 2:23 PM
Hi Chris
Thanks - I have run a few speed tests and there are improvements averaging 25-30mb now, still well down on 80mb though
Nokk
Nokk
Message 3 of 6
(591 Views)
16-05-2014 2:29 PM
Can you connect with an Ethernet Cable and re-run the speed tests please?
Wireless Speeds aren't a very good indication of how your line is performing.
Message 4 of 6
(591 Views)
16-05-2014 2:41 PM
Hi Chris
good news - Wired up i now get 74mb down and 17mb up - thats not bad
Thanks for your help
Nokk
Nokk
Message 5 of 6
(591 Views)
16-05-2014 2:42 PM
Woohoo
Message 6 of 6
(591 Views)
