Sync rate increasing, download speeds stuck
- Sync rate increasing, download speeds stuck
10-10-2009 6:37 PM
I've seen my sync rate gradually increase from 2MBits to 3.5MBits in the last few weeks but in all that time my download speeds (throughput) have stayed bang on 1.8MBits.
Any ideas?
Cheers
ComplexP
Re: Sync rate increasing, download speeds stuck
10-10-2009 7:05 PM
Might be worth try out something like routerstats to see if you can identify exactly when these syncs happen and if anything else occurs at the same time.
10-10-2009 7:39 PM
Is Routerstats some sort of logging program? How does it work please?
Thanks again.
11-10-2009 9:37 AM
I've done a little research and found the program you were referring to. I have a standard issue Thompson router so it was very easy to set up. I'll leave Routerstats monitoring for the week and see what happens.
For your information, when I started Routerstats at 09:28 this-morning I had a sync rate of 3523 and a noise margin of 8.5dB (actual download speeds still at 1.8 ). According to the router this had been a solid connection for 19.5 hours at that point.
Fingers crossed this will point to a clear cause for these random resyncs.
One question though: Assuming these resync issues are temporary what approximate length of stable connection time should I wait before expecting to see an improvement in the download speeds?
Regards
ComplexP
11-10-2009 9:05 PM
12-10-2009 7:56 AM
I've been watching the Routerstats program closely and noticed that the connection has been fine yesterday apart from 2 disconnections in quick succession at 18:54 and then again at 19:04. Both resynced quickly to be slightly under their previous number. At the same time I saw the noise margins plummet for a few seconds each time to about 2-3dB (although I suspect this is just a function of the router disconnecting?)
There was nothing unusual happening prior to these occurances in the house or on the routerstats.
I currently have my filter plugged directly into the test socket before you ask.
I am yet to see the resync rates of 2.3 that you mentioned before Chris but I will keep waiting to see.
My question of the day: If the router resysncs to a slight change in sync rate without that random 2.3 appearing should I eventually see an increase in throughput? I was under the impression that routers resync all the time with minon connection rate fluctuations and it's no big deal. Perhaps I'm wrong.
Thanks all.
12-10-2009 10:12 AM
I'm seeing you as being connected @ 3.1Mbps currently, but we're yet to see an increase on your profiled speed. Sometimes it can take as much as 5 days, but hopefully it won't be that long.
12-10-2009 10:59 AM
My router seems to average a resync once per day, although these are normally only a small change up or down. However, it does disconnected for a few seconds during these resyncs. Could this be enough to stop my profiled speed from increasing or do I not need to worry?
ComplexP
12-10-2009 11:07 AM
12-10-2009 11:33 AM
Quote from: Jameseh
12-10-2009 12:17 PM
Apparently the reason my profile is not increasing is because my sync rate randomly dropped to 2.3MBits for a few hours/mins before jumping back up at some point several days ago. It happened so quickly I missed it which is why I'm now continuously monitoring my sync rates using Routerstats.
So far I have not noticed it happening again (so hopefully I'll see my profile increase soon) but is it possible something similar is happening to you? If your sync rates are dropping massively for a few minutes during the night you may never know it's happening.
adie:quote
13-10-2009 8:54 AM
Still connected at about 3.1MBits. No disconnections overnight. I think it must be close to 3 days since that random 2272 Chris mentioned and it definately hasn't occured again. Profile still not changed.
