Sync, ping and upload same as always, download speed halved.
racquel
Does anything look odd here? LAN cable connection, have rebooted router etc:
BT Wholesale test reports:
Download speedachieved during the test was - 2.45 Mbps
For your connection, the acceptable range of speeds is 2 Mbps-7.15 Mbps.
IP Profile for your line is - 6.54 Mbps
Upload speed achieved during the test was - 0.79Mbps
Additional Information:
Upstream Rate IP profile on your line is - 0.83 Mbps
Speedtest.net last few results
11/1/2016 11:10 GMT	2425 kb/s	810 kb/s	35 ms
11/1/2016 10:19 GMT 2384 kb/s 736 kb/s 33 ms
8/1/2016 13:36 GMT 5312 kb/s 799 kb/s 32 ms
4/1/2016 09:29 GMT 3604 kb/s 698 kb/s 36 ms
31/12/2015 14:27 GMT 5650 kb/s 794 kb/s 37 ms
Router reports:
7 - Data rate:	984/7405
8 - Maximum data rate: 996/7536
9 - Noise margin: 6.0/2.5
10 - Line attenuation: 25.9/49.5
12 - Data sent/received: 7.8M/22.7M
In other words, everything is the same, but download speed has halved and I had trouble completeing speedtest.net tests several times - download just stopped while other sites were up.
(note: BT test concurs with speedtest, so not a speedtest.net problem)
12 REPLIES 12
Fixes: 160
Re: Sync, ping and upload same as always, download speed halved.
Hi Racquel,
Yes things do look odd!  Is your router monkeying around with the DS SNRM?
The DS synch speed is way over the top for the line's reported attenuation; 5.5+Mbps is the most I'd expect on a 50dB line at 6dB.
Your line is attempting 7.5Mbps at 2.5dB.  I suspect that the 'benefit' of the higher synch speed achieved by pushing down the SNRM is completely lost by the resultant increase in line errors, requiring data to need to be retransmitted.
If your router is not monkeying around with the SNRM, then you might see a marked improvement in data speed by having the synch rate reduced by an increased Target SNRM of 6dB.  If the target is already 6dB, then the above stats indicate the presence of interference.
Is the phone line quiet?  Dial 17070 option2.
Kevin
racquel
Thanks.
No idea how I could tell if there was any monkeying going on - all I know is that it's been fine until this morning.
Quiet line test OK - volume good, no crackling. Don't really want to reduce sync speed much as it's only recently we've got a stable iplayer HD stream.
Apparently we were promised FTTC over a year ago - all they keep doing is coming out and patching the line up when the little plastic pole-dildos fall off, dangle upside-down and fill with water.
Still, it's good to know that it's "in our area".... (hmmm).
Fixes: 160
Quote from: racquel
You do not need 7+Mbps to do that.  If the higher synch speed drives down your effective data speed (which is what is really important) you will improve the effective data speed by reducing the synch speed because there will be fewer errors on the line.
When you stated that the speed test was over a cable, was the wifi interface on the PC (if it has one) turned off?  Just because there is a cable between the PC and the router, one should not assume that it will be used in preference to an (also) active wifi connection.
@CRT,
What is the target SNRM on this line please?  How stable has it been of recent times?
racquel
Does anyone know how many days Plusnet are currently taking to get round to tickets?
Nothing at all since this last action:
11:42am, Monday 11 Jan 2016
Your support request has been escalated to the correct team for review.
http://www.plus.net/supportpages.html?a=212 says:
Average closure time Target closure time
9 hours, 53 minutes and 43 seconds 24 hours
There was a brief time yesterday when I could actually do stuff, but as you can see from below, it's back to normal now.
TEST_DATE	      DOWNLOAD   UPLOAD   LATENCY_MS
14/01/2016 06:34 1777 777       39
13/01/2016 11:07 5179 835       30
12/01/2016 10:02 2448 842       32
11/01/2016 17:04 2222 841       32
11/01/2016 11:34 2481 825       32
Router stats and BT speed test/IP profile have changed though...
7 - Data rate:	976/3367
8 - Maximum data rate: 988/6496
9 - Noise margin: 6.2/16.9
10 - Line attenuation: 25.8/46.5
 Download speedachieved during the test was - 2.85 Mbps
For your connection, the acceptable range of speeds is 1.2 Mbps-4 Mbps.
IP Profile for your line is - 2.97 Mbps
Upload speed achieved during the test was - 0.82Mbps
Fixes: 160
Looks like the line has been capped / the target SNRM has been jacked up to achieve stability.
This needs CRT input.
Chris
Legend
Fixes: 169
Quote from: racquel
There should be a comment that fault investigations aren't included in that average:
These question handling stats relate to questions directed at our front-line support team. More complex issues, fault investigations and issues that require the help of other departments within the business may take longer to turnaround.
I'm taking a look at the line tests now.
Chris
Legend
Fixes: 169
The SNR margin is set at 3db, however the SNR is currently at 17.1db. This would normally suggest the line has become banded, however the profile of the line doesn't show that.
There haven't been many disconnections, but each disconnection seems to have the sync rate varying significantly.
I've put a reset through on your line, and will leave the fault ticket open for our faults team to investigate further.
Are you plugged in to the master socket? The changes in SNR and sync are concerning and it's good to check everything is connected as well as it can be.
racquel
Thanks!
Yup! The only thing plugged in.
In fact, following a suggestion last year, it's plugged directly into the socket behind the master socket (test socket?), which gained us another mb or so.
It's been fine (if you consider 4-5mb "fine" in 2016) up until the last couple of weeks.
Remember, we're at the end of a long crappy line of overhead wires.. doesn't help.
racquel
OK, things seem a little snappier now; I've just done a speed test and we're getting a blazing fast 4.8Mb/sec, which is at least workable.
Many thanks for doing the reset.
Fixes: 160
Can you please post current router stats.  I'm concerned that the improvement will inky be temporary until the DLM kicks in again.  Hopefully though faults will have found something in that time frame.
racquel
6 - Uptime:	0 days 05:27:26
7 - Data rate: 976/5988
8 - Maximum data rate: 996/6028
9 - Noise margin: 6.3/8.0
10 - Line attenuation: 25.8/49.5
cedlor
Quote from: racquel
Thanks!
Via a filter?
