Sync drops when phone rings (subject was "Is this a record?)
- Sync drops when phone rings (subject was "Is this ...
Re: Is this a record?
20-03-2013 5:53 PM
20-03-2013 6:03 PM
The bits tone graph looks pretty normal to me.
There's obviously something wrong with the line if it drops on an incoming call with no phone attached. I'll get that sorted first and then reassess the situation. If I can get a totally stable 6000 (fast enough for HD iPlayer) I'd be happy.
Current stats:
Link Information
Uptime: 0 days, 6:19:09
DSL Type: ITU-T G.992.1
Bandwidth (Up/Down) [kbps/kbps]: 832 / 7.616
Data Transferred (Sent/Received) [MB/MB]: 86,18 / 487,64
Output Power (Up/Down) [dBm]: 12,5 / 19,8
Line Attenuation (Up/Down) [dB]: 14,0 / 21,0
SN Margin (Up/Down) [dB]: 12,0 / 5,9
Chipset Vendor ID (Local/Remote): BDCM / ????
Loss of Framing (Local/Remote): 34 / -
Loss of Signal (Local/Remote): 4 / -
Loss of Power (Local/Remote): 0 / -
Loss of Link (Remote): -
Error Seconds (Local/Remote): 59 / -
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 879 / 4
HEC Errors (Up/Down): - / 3
20-03-2013 6:24 PM
Is that still with 10.2.2.9 firmware? Is there any significant bit swapping on the US?
20-03-2013 6:31 PM
Nothing significant on the bitswaps/tone. It's pretty much flat right across all tones (up and down) with 2 swaps per tone.
20-03-2013 7:01 PM
21-03-2013 10:31 AM
21-03-2013 11:19 AM
Me: When the phone rings for an incoming call the broadband drops
Them: Is the phone working OK?
Me: Yes
Them: Any noise on the line?
Me: No
No prizes for guessing what their response is likely to be!
21-03-2013 1:28 PM
Quote from: Matt Unfortunately we weren't able to get it to run, though that did enable us to raise the fault. It's been cleared with "15 - 556 - BTW cannot progress this fault as the root cause is the PSTN failure. Please report to your Copper Line Service Provider." so looks like it is a fault with the phone line - not sure we'll be able to progress this any further as a broadband fault now we've received that result.
There's nothing on my ticket about BTw clearing the fault - is that coming?
BTW: Only one incoming call so far today at 12:16
[quote=Router log]<173> Mar 21 12:16:56 xDSL linestate down
<173> Mar 21 12:17:10 xDSL linestate up (ITU-T G.992.1; downstream: 7584 kbit/s, upstream: 832 kbit/s; output Power Down: 19.8 dBm, Up: 12.5 dBm; line Attenuation Down: 21.0 dB, Up: 14.0 dB; snr Margin Down: 6.1 dB, Up: 12.0 dB)
The PPP did not drop.
21-03-2013 3:09 PM
Our testing has failed at the Local Exchange. I've arranged for a Frames Engineer to go out to get that sorted for you.
Should all be sorted within 48 hours for you
21-03-2013 3:18 PM
Thanks Chris
22-03-2013 9:36 AM
What a surprise!
26-03-2013 9:30 AM
At least it's progress - confirmed it's not my end and confirmed that it's not the wires from here to the exchange.
26-03-2013 10:58 AM
27-03-2013 1:52 PM
Quote Dear Mr xxx,
Further to my message, our suppliers are arranging the move to new pairs. We'll continue to check for updates on a regular basis and pass information on as soon as it becomes available. Apologies for any inconvenience caused.
Kind regards,
<removed>
--internal--
EC ref 197352799
I will go ahead and passed this to EM Assit team to provide the new tie pair and if required they will send out transmission engineer.
28-03-2013 12:40 AM
