Swap from ADSL MAX to wbc Re ticket 511978036
- Swap from ADSL MAX to wbc Re ticket 511978036
- « Previous
- 1
- 2
- Next »
Re: Swap from ADSL MAX to wbc Re ticket 511978036
23-03-2012 10:24 AM
26-03-2012 3:00 PM
G.DMT2+ Annex A
sync 5093 target is now 3 on fast path with a atten 52
I will see how things go
26-03-2012 4:59 PM
26-03-2012 5:10 PM
27-03-2012 8:29 AM
Such a shame as it was so stable as long as the exchange kept me on adsl2
27-03-2012 1:41 PM
I don't think it would go on ADSL2 unless the sync was lower. I've just been having a Google around and it doesn't look like you can telnet with that router or force modulation, so I'm not sure what you could do apart from changing router. That said, I think your line's performing really well.
Jojo
27-03-2012 2:28 PM
The 2700hg 2wire is very good on long lines but lacks modification.
Yes line is dooing well but I was supprised of the changes since we had the 6db and interleaving applied and it stayed on adsl2.
I do not know why the change to adsl2+ took place or why I am now fast path with 3db target snr?
27-03-2012 2:44 PM
Quote from: adamtemp64 I do not know why the change to adsl2+ took place or why I am now fast path with 3db target snr?
Neither do I, but I wouldn't change things for now, unless it started to cause problems.
27-03-2012 2:53 PM
I have just dug out my supplied old 585v7 and am flashing latest firmware will try that later and see what results I get.
27-03-2012 5:12 PM
xdsl debug multimode config=t1.413issue2+g992.3_annex_a
27-03-2012 5:17 PM
27-03-2012 5:32 PM
28-03-2012 9:51 AM
28-03-2012 10:17 AM
It should just have one that says 'other'. All the other settings will be same anyway, so if you just go past that you'll be able to enter your username and password.
Jojo
- « Previous
- 1
- 2
- Next »
