Sudden drop in sync and no dial tone
- Sudden drop in sync and no dial tone
- « Previous
- 1
- 2
- Next »
Re: Sudden drop in sync and no dial tone
27-02-2014 1:54 PM
The connection has gone back to ITU-T G.992.5.
[quote=Stats]Uptime: 0 days, 3:21:20
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 888 / 5.923
Data Transferred (Sent/Received) [MB/GB]: 406,53 / 1,37
Output Power (Up/Down) [dBm]: 12,7 / 0,0
Line Attenuation (Up/Down) [dB]: 25,2 / 47,5
SN Margin (Up/Down) [dB]: 6,3 / 5,8
I note that the Attenuation has gone up to 47.5 from 44.5 last night- why would this be? The Attentuation never changed when the SNR was increased from 6 to 9dB - is this symptomatic of a problem still on the line?
Edit: BT profile is currently 5.22 but PN's is set to 5.9.
Forum Moderator and Customer
27-02-2014 1:56 PM
I think the best thing to do would be to keep an eye on things for a week or so and see how the line performs.
27-02-2014 2:28 PM
So far so good - the only drop since the repair being subsequent to the SNR reset this morning as far I can see
19-03-2014 4:03 PM
Still had quite a few drops since the line as fixed last month.
To eliminate the router being a potential issue I swapped in my HH2 (used this as it saved having to change IP addresses across all devices).
I still got the odd drop (last one was about 5 days ago) but was much more stable with a sync of around 5500, SNR around 6dB and Att reported at 44.5dB.
Lost connection again around 20 minutes ago, latest stats:
Quote Line state Connected
Connection time 0 days, 0:18:57
Downstream 5,429 Kbps
Upstream 872 Kbps
ADSL settings
VPI/VCI 0/38
Type PPPoA
Modulation ITU-T G.992.5
Latency type Interleaved
Noise margin (Down/Up) 6.5 dB / 5.0 dB
Line attenuation (Down/Up) 47.0 dB / 24.9 dB
Output power (Down/Up) 0.0 dBm / 12.9 dBm
I note that the Att has gone back up to 47dB.
Could someone have a look into this, please?
Edit: Just had another drop, new stats:
Connection time 0 days, 0:01:08
Downstream 5,511 Kbps
Upstream 888 Kbps
ADSL settings
VPI/VCI 0/38
Type PPPoA
Noise margin (Down/Up) 6.2 dB / 5.8 dB
19-03-2014 5:00 PM
<img src="http://community.plus.net/visualradius/generated/image13952481461726.png"/>
I wouldn't say they are anything to worry about though unless this starts to happen on a regular basis.
I've taken a look over your line and everything looks fine. If you could keep an eye on it and if this continues to happen, please let us know.
19-03-2014 5:06 PM
I was concerned more about the increase in Att. It's not because of the change of router as the HH2 was reporting it as 44.5dB - same as the Thomson - till this afternoon's increase.
19-03-2014 5:13 PM
It's really service impacting if your Line Attenuation jumps quite significantly.
19-03-2014 5:17 PM
It's just a shame the HH2 isn't compatible with either RouterStats or ThinkBroadband monitor.
19-03-2014 5:21 PM
19-03-2014 5:30 PM
I lent my other Thomson (v8, I think) to my daughter who has never used it so will ask her to return it.
19-03-2014 6:33 PM
19-03-2014 7:27 PM
It will be interesting to see what the Thomson displays when I get it back.
But, your post still doesn't explain how the Attenuation changed on the same router from 44.5 to 47
19-03-2014 8:12 PM
19-03-2014 8:20 PM
- « Previous
- 1
- 2
- Next »
