Such inconsistent speeds over wifi
HNKS
I can achieve my maximum download speed via wifi but it lasts for seconds. Then it can drop as low as 16Mb. Thats what I had on ADSL2+.
Cant believe Plusnet use such a shocking wireless router. I depend on wireless as my router is awkwardly placed. Sad
4 REPLIES 4
HNKS
Re: Such inconsistent speeds over wifi
Seriously this sucks. It goes from 50 to 35 to 20. Sometimes even lower. Sad
tijara33
Fixes: 6
Bite the bullet, do what I did. Treat yourself to an Asus RT-N56U, it's brilliant with lots of useful features, particularly dual channel operation.
Velocity
Quote from: tijara33
Apart from extra features do you find there is any worthwhile measurable improvement in Down/Up speeds. Stability etc
HNKS
Quote from: Velocity
I also want to know this.
Im thinking of homeplugs as they are cheaper.
