Such inconsistent speeds over wifi
- Re: Such inconsistent speeds over wifi
18-01-2013 10:35 PM
I can achieve my maximum download speed via wifi but it lasts for seconds. Then it can drop as low as 16Mb. Thats what I had on ADSL2+.
Cant believe Plusnet use such a shocking wireless router. I depend on wireless as my router is awkwardly placed.
Message 1 of 5
(921 Views)
4 REPLIES 4
19-01-2013 8:23 PM
Seriously this sucks. It goes from 50 to 35 to 20. Sometimes even lower.
Message 2 of 5
(427 Views)
19-01-2013 9:18 PM
Bite the bullet, do what I did. Treat yourself to an Asus RT-N56U, it's brilliant with lots of useful features, particularly dual channel operation.
Message 3 of 5
(427 Views)
20-01-2013 6:25 PM
Quote from: tijara33 Bite the bullet, do what I did. Treat yourself to an Asus RT-N56U, it's brilliant with lots of useful features, particularly dual channel operation.
Apart from extra features do you find there is any worthwhile measurable improvement in Down/Up speeds. Stability etc
Message 4 of 5
(427 Views)
20-01-2013 8:27 PM
Quote from: Velocity
I also want to know this.
Im thinking of homeplugs as they are cheaper.
Message 5 of 5
(427 Views)
