Sub-standard performance on Pro/PAYG
- Sub-standard performance on Pro/PAYG
Re: Sub-standard performance on Pro/PAYG
14-12-2009 12:36 PM
Have you tried any of the affected accounts from one of your test lines?
14-12-2009 12:46 PM
Quote from: jelv It's beginning to look like this problem affects more than just Pro/PAYG.
Plusnet Premium user with IP Profile of 7150 getting 774 Kbps at around mid-day.
Exchange is green
I was too. But changed up to Pro based on your suggestions to rule out any kind of traffic management.
14-12-2009 12:49 PM
Quote from: jelv
Quote from: Jarvo BUT I do suspect that MyBroadbandSpeed is within PN's network when testing.
Correct: it's in the same location as the thn gateways.
That's why it's the best one to use - Plusnet can hardly argue with the results from their own tester!
Ah, thanks for confirming, I hadn't got round to whois and tracerts. I do think it's wise to do a combination of testing, as it allows you to see on-net and off-net speeds. EG, is the backhaul to blame or inter-network routing.
14-12-2009 5:20 PM
Quote from: chesterfield Ive been searching through the status updates for anything relating to the time this fault started appearing, which, going by my last "good" speed test, appears to be on or around the 8th of December, and I found this one:
Quote Planned Transit Maintenance - Tuesday 8th December 2.30pm-5.00pm
When's this work happening?
This afternoon, 8th December.
What does it affect?
The route some of your traffic takes across the Internet.
How long will it take?
About fifteen minutes.
What does the work involve?
We will be routing some customer traffic via a newly established peering arrangement.
Is there any more detail available, as this is looking the most likely suspect for now.
Doubt it's related TBH, that work involved advertising more routes over our newly established BT peering arrangement.
Quote C:\Users\Bobby>tracert amazon.com
Tracing route to amazon.com [72.21.210.250]
over a maximum of 30 hops:
1 1 ms 1 ms 2 ms gateway.anfield [192.168.1.1]
2 33 ms 33 ms 34 ms lo0-homesurf.pte-ag2.plus.net [195.166.128.73]
3 28 ms 43 ms 36 ms ge0-0-0-505.pte-gw2.plus.net [84.92.4.98]
4 31 ms 32 ms 32 ms vl23.thn-gw2.plus.net [212.159.4.20]
5 33 ms 34 ms 32 ms t2a4-ge4-0-0.uk-lon1.eu.bt.net [166.49.211.129]
6 36 ms 36 ms 42 ms t2c2-ge7-3.uk-lon1.eu.bt.net [166.49.135.114]
7 32 ms 35 ms 35 ms t2c1-p4-2.uk-eal.eu.bt.net [166.49.164.137]
8 113 ms 115 ms 113 ms t2c1-p4-0-0.us-ash.eu.bt.net [166.49.164.225]
9 * * * Request timed out.
10 ^C
Quote It appears as those affected are having all their traffic either classed as bronze, or unclassified at all - hence the enormous drop at peak time.
Has anybody verified this with a Wireshark capture?
14-12-2009 6:28 PM
Quote First run the BT Speedtest
Download speedachieved during the test was - 931 Kbps
Additional Information:
Your DSL Connection Rate :8096 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 7150 Kbps
Quote Second run a second speedtest on Mybroadbandspeed
Quote Third run a tracert to www.mybroadbandspeed.com
Tracing route to www.mybroadbandspeed.com [84.92.1.14]
1 1 ms <1 ms <1 ms 192.168.1.1
2 52 ms 50 ms 49 ms lo0-homesurf.pte-ag2.plus.net [195.166.128.73]
3 53 ms 75 ms 52 ms ge0-0-0-505.pte-gw1.plus.net [84.92.4.97]
4 52 ms 49 ms 49 ms vl22.thn-gw1.plus.net [212.159.4.3]
5 52 ms 48 ms 49 ms 84.92.1.14
Trace complete.
Quote Fourth run a tracert to www.speedtester.bt.com
Tracing route to www.speedtester.bt.com [217.32.105.42]
1 1 ms 3 ms 1 ms 192.168.1.1
2 50 ms 50 ms 50 ms lo0-homesurf.pte-ag2.plus.net [195.166.128.73]
3 50 ms 48 ms 49 ms ge0-0-0-505.pte-gw2.plus.net [84.92.4.98]
4 49 ms 49 ms 49 ms te3-2.ptn-gw02.plus.net [212.159.1.105]
5 48 ms 47 ms 49 ms linx2.ukcore.bt.net [195.66.226.10]
6 51 ms 51 ms 52 ms core2-pos0-14-4-0.ilford.ukcore.bt.net [195.99.125.230]
7 50 ms 53 ms 50 ms core2-pos9-0.stalbans.ukcore.bt.net [194.74.16.222]
8 51 ms 50 ms 53 ms vhsaccess2-gig1-0.stalbans.fixed.bt.net [217.32.169.148]
14-12-2009 6:36 PM
Dave asked for some other stats, here they are:
BT Speedtest
Download speed achieved during the test was - 470 Kbps
Your DSL Connection Rate :7936 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 6000 Kbps
MyBroadbandSpeedTest
Today 18:30 Down = 635 kbps (79.4kB/s) Up = 375 kbps (46.9kB/s)
BT Traceroute
1 1 ms <1 ms <1 ms www.routerlogin.com [192.168.0.1]
2 38 ms 35 ms 37 ms lo0-plusnet.pte-ag1.plus.net [195.166.128.64]
3 147 ms 209 ms 215 ms ge0-0-0-403.pte-gw2.plus.net [84.92.4.2]
4 150 ms 210 ms 207 ms te3-2.ptn-gw02.plus.net [212.159.1.105]
5 38 ms 36 ms 38 ms linx2.ukcore.bt.net [195.66.226.10]
6 42 ms 38 ms 38 ms core1-pos9-0-0.telehouse.ukcore.bt.net [194.74.65.117]
7 44 ms 43 ms 37 ms core2-pos9-0.stalbans.ukcore.bt.net [194.74.16.222]
8 37 ms 39 ms 38 ms vhsaccess2-gig1-0.stalbans.fixed.bt.net [217.32.169.148]
10 * * * Request timed out.
(all we get from here is Request timed out)
Tracing route to homepages.plus.net [212.159.8.91]
1 <1 ms <1 ms <1 ms www.routerlogin.com [192.168.0.1]
2 59 ms 37 ms 39 ms lo0-plusnet.pte-ag1.plus.net [195.166.128.64]
3 37 ms 35 ms 36 ms ge0-0-0-403.pte-gw2.plus.net [84.92.4.2]
4 38 ms 35 ms 37 ms te3-2.ptn-gw02.plus.net [212.159.1.105]
5 37 ms 35 ms 39 ms te3-1.ptn-gw01.plus.net [212.159.1.109]
6 47 ms 48 ms 46 ms gi3-0.pih-cr1.plus.net [212.159.1.177]
7 47 ms 46 ms 50 ms vlan7.pih-gw3.plus.net [212.159.0.26]
8 52 ms 53 ms 51 ms if25.pih-lb04.plus.net [212.159.0.18]
9 49 ms 44 ms 49 ms homepages.plus.net [212.159.8.91]
Trace complete.
Hope this info is helpful.
14-12-2009 6:36 PM
could an issue at the PN end effect my phone line even if i'm on BT.
have attached speed from this morning and now
my speeds have been suffering long before this latest issue
14-12-2009 7:12 PM
Test1 comprises of Best Effort Test: -provides background information.
Download Speed
269 Kbps
0 Kbps 7150 Kbps
Max Achievable Speed
Download speedachieved during the test was - 269 Kbps
Your DSL Connection Rate :4160 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 3000 Kbps
C:\Windows\system32>tracert www.mybroadbandspeed.com
1 15 ms 99 ms 99 ms dsldevice.lan [192.168.1.254]
2 48 ms 44 ms 46 ms lo0-plusnet.pte-ag2.plus.net [195.166.128.72]
3 45 ms 50 ms 48 ms ge0-0-0-504.pte-gw1.plus.net [84.92.4.89]
4 44 ms 50 ms 46 ms vl22.thn-gw1.plus.net [212.159.4.3]
5 59 ms 46 ms 46 ms 84.92.1.14
Trace complete.
C:\Windows\system32>tracert www.speedtester.bt.com
1 10 ms 172 ms 25 ms dsldevice.lan [192.168.1.254]
2 45 ms 46 ms 47 ms lo0-plusnet.pte-ag2.plus.net [195.166.128.72]
3 55 ms 48 ms 45 ms ge0-0-0-504.pte-gw2.plus.net [84.92.4.90]
4 49 ms 50 ms 48 ms te3-2.ptn-gw02.plus.net [212.159.1.105]
5 46 ms 45 ms 46 ms linx2.ukcore.bt.net [195.66.226.10]
6 51 ms 44 ms 47 ms core1-pos9-0-0.telehouse.ukcore.bt.net [194.74.6
5.117]
7 46 ms 51 ms 47 ms core2-pos9-0.stalbans.ukcore.bt.net [194.74.16.2
22]
8 48 ms 45 ms 48 ms vhsaccess2-gig1-0.stalbans.fixed.bt.net [217.32.
169.148]
11 * * * Request timed out.
12 * * * Request timed out.
13 * * * Request timed out.
14 * * * Request timed out.
15 * * * Request timed out.
16 * * * Request timed out.
17 * * * Request timed out.
18 * * * Request timed out.
19 * * * Request timed out.
20 * * * Request timed out.
21 * * * Request timed out.
22 * * * Request timed out.
23 * * * Request timed out.
24 * * * Request timed out.
25 * * * Request timed out.
26 * * * Request timed out.
27 * * * Request timed out.
28 * * * Request timed out.
29 * * * Request timed out.
30 * * * Request timed out.
Trace complete.
14-12-2009 9:59 PM
14-12-2009 10:04 PM
14-12-2009 10:06 PM
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
C:\Documents and Settings\Haydn>tracert bbc.co.uk
Tracing route to bbc.co.uk [212.58.224.138]
1 5 ms 99 ms 99 ms dsldevice.lan [192.168.1.254]
2 44 ms 35 ms 44 ms lo0-plusnet.pcl-ag02.plus.net [195.166.128.39]
3 47 ms 37 ms 38 ms gi1-2-904.pcl-gw02.plus.net [84.92.0.141]
4 58 ms 44 ms 90 ms te2-2.thn-gw2.plus.net [212.159.0.190]
5 40 ms 40 ms 57 ms rt0.thdo.bbc.co.uk [212.58.239.25]
6 174 ms 201 ms 198 ms 212.58.238.133
7 40 ms 44 ms 41 ms virtual-vip.thdo.bbc.co.uk [212.58.224.138]
Trace complete.
14-12-2009 10:22 PM
Quote its all gone wrong!!!!! my bt phoneline went all together and my line profile has gone to rats poo. my phone is sort of back but has a loud hiss.
I think you have a totally different issue and that your BB has been affected by deterioration of your phone line, report it to BT even if it is "sort" of working as the noise won't do you BB profile any good
14-12-2009 11:15 PM
15-12-2009 6:36 AM
Nothing in the PN network can affect the quality of your line or connection to the exchange. You need to confirm you can still hear the noise at the test socket with a corded phone. If it's not present, it's something to do with your setup.
If it's still there, phone your line provider (151 option 2 if BT), and go directly to speak to an adviser, do so whilst the noise is still present, and try and do so quickly before you receive an incoming call because ringing on the line can often clean a bad connection. Do not use any automated tests and do not mention the broadband this is a phone fault you are reporting, otherwise you'll get given the run around. Make sure the adviser can hear the noise, get them to confirm it and log it and log it as intermittent with the request that they ensure Openreach are made aware it's intermittent.
I'm assuming you may have already done this from your last post, but nevertheless put the above information in for the benefit of others.
15-12-2009 7:56 AM
this must have occured during the day yesterday as in the morning my profile, speed test and telephone were all fine.
i have a filtered face plate on the master socket, with just one broadband line and one phone line coming off it.
my speeds were solid at around 6700 for weeks until the issue that everyone else has and my connection never drops unless i reboot
i wont be back up to speed for weeks while i wait for everything to settle so will watch this post from the sidelines
cheers
