Sub-standard performance on Pro/PAYG
- Sub-standard performance on Pro/PAYG
Re: Sub-standard performance on Pro/PAYG
07-01-2010 10:58 AM
3Mb FTTC
07-01-2010 3:03 PM
Download speedachieved during the test was - 2230 Kbps
Additional Information:
Your DSL Connection Rate :7616 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 6500 Kbps
07-01-2010 3:09 PM
I have an illness whereby I need to sleep at night in order to function in the daytime so this is playing hell with my health at the moment having to gateway hop into the early hours so it looks like I'll have to move on as I can't carry on like this
details for info weather bright sunny and no snow or freezing cold I grant you but a great day, no exchange congestion
Download speedachieved during the test was - 4550 Kbps
Your DSL Connection Rate :8128 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 7150 Kbps
(so which one is right)
Estimated line speed:
8 - Checked on 2009-08-17 10:44:58
Current line speed:
7150
Currently connected to pcl-ag04 but will most probably have to hop later
DSL Type: G.992.1 annex A
Bandwidth (Up/Down) [kbps/kbps]: 448 / 8,128
Output Power (Up/Down) [dBm]: 11.5 / 17.5
Line Attenuation (Up/Down) [dB]: 9.0 / 15.0
SN Margin (Up/Down) [dB]: 20.0 / 11.5
Vendor ID (Local/Remote): TMMB / ALCB
Loss of Link (Remote): 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 0 / 33
HEC Errors (Up/Down): 0 / 25
Wait till 1am and I'll be lucky to see 2mbps
07-01-2010 3:24 PM
Quote from: buffyrat ... I usually get 6000kbps but I'm getting 1000-3000kbps at the mo (see BT test results below)...
which shows you have an exchange congestion problem, you would get a similar result with any ISP like PN that use BT for their ADSL connections.
3Mb FTTC
07-01-2010 4:03 PM
dick:quote
07-01-2010 9:07 PM
08-01-2010 12:45 AM
08-01-2010 7:55 AM
08-01-2010 8:39 AM
Quote from: buffyrat ... how you deduce that from these results?
The BT speedtester is a speed test of data transfer over the BT network itself, so removing PN from the equation for a moment. If the BT speedtest gave a good result but a speedtest.net test gave a poor or very different result it could indicate a PN problem.
3Mb FTTC
08-01-2010 9:26 AM
Quote from: godsell4 The BT speedtester is a speed test of data transfer over the BT network itself, so removing PN from the equation for a moment. If the BT speedtest gave a good result but a speedtest.net test gave a poor or very different result it could indicate a PN problem.
I never realised that... obvious now I think about. Thanks for that
08-01-2010 10:17 AM
08-01-2010 1:39 PM
09-01-2010 12:55 PM
09-01-2010 7:22 PM
Mode G.dmt Line State Show Time
Latency Type Interleave Line Up Time Duration 78:22:55:42
Line Coding Trellis Off Line Up Count 1
Statistics Downstream Upstream
Line Rate 3808 Kbps 448 Kbps
Attainable Line Rate 4224 Kbps 964 Kbps
Noise Margin 7.8 dB 19.0 dB
Line Attenuation 50.0 dB 29.0 dB
Output Power 11.9 dBm 18.9 dBm
Interface Received Transmitted
Bytes Packets Errors Drops Bytes Packets Errors Drops
Ethernet 981,380,714 4,631,353 0 0 1,216,609,885 20,526,006 0 0
USB 0 0 0 0 0 0 0 0
Wireless 522,245,536 2,455,670 0 0 3,279,558,164 8,125,933 951 0
WAN 2,477,883,282 4,605,541 806 806 740,214,745 4,472,653 325 0
BT Speedtest
Download speedachieved during the test was - 2583 Kbps Additional Information:
For your connection, the acceptable range of speeds Your DSL Connection Rate :3808 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
is 600-7150 Kbps. IP Profile for your line is - 3000 Kbps
My Broadband speed test
Today 14:21 3242 kbps (405kB/s) 255 kbps (31.9kB/s)
Line Rate 3500
Tuesday 5th Jan
Today 20:59 2732 kbps (342kB/s) 366 kbps (45.8kB/s
07/01/2010 18.07 So where did my bandwidth go?
Status > ADSL Line
Line Mode G.dmt Line State Show Time
Latency Type Interleave Line Up Time Duration 01:21:00:59
Line Coding Trellis Off Line Up Count 9
Line Rate 1856 Kbps 448 Kbps
Attainable Line Rate 2048 Kbps 992 Kbps
Noise Margin 9.0 dB 19.0 dB
Line Attenuation 48.5 dB 28.0 dB
Output Power 11.9 dBm 17.5 dBm
Ethernet 1,503,475,868 7,205,188 0 0 4,111,351,721 31,936,998 0 0
USB 0 0 0 0 0 0 0 0
Wireless 755,551,190 3,642,696 0 0 632,220,514 12,541,222 1,551 0
WAN 50,126,878 132,761 0 0 25,812,314 139,980 0 0
My Broadband speedtest
Today 18:14 1152 kbps (144kB/s) 369 kbps (46.1kB/s) Current line speed: Today 21:37 1132 kbps (142kB/s) 284 kbps (35.5kB/s
1250
09/01/2010
BT Test result FAQ
Download Speed
1098 Kbps
0 Kbps 2000 Kbps
Max Achievable Speed
Download speedachieved during the test was - 1098 Kbps
For your connection, the acceptable range of speeds is 400-2000 Kbps.
Your DSL Connection Rate :1856 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 1250 Kbps
My Broadband
Today 18:16 1310 kbps (164kB/s) 372 kbps (46.5kB/s)
Exchange is "Green"
You are currently connected to the "Telehouse East, Juniper 3" gateway. This gateway is sometimes known as pte-ag1.
Before Christmas I probably had the best speed/response since moving to MK over 2 years ago. What happened?
09-01-2010 11:07 PM
You have a problem with your connection to the exchange and your current sync speed indicates it is an ongoing issue. I suggest you start a separate topic giving the stats reported by the router and we'll help you work through it.
