Stuck at 2000 kbs again
andyrpsmith
I seem to be stuck at 2000kbs down load speed again. This happened a few months ago for some reason. Could you have a look to see if the profile is stuck.
Many thanks
Andy
Fixes: 167
Re: Stuck at 2000 kbs again
What results does a BT speedtest give you? Interested in the IP profile and the throughput speed.
 Chris Parr
 Plusnet Staff
andyrpsmith
Hi Chris,
The following results obtained:
Download speedachieved during the test was - 1.93 Mbps
For your connection, the acceptable range of speeds is 0.6 Mbps-7.15 Mbps.
Additional Information:
Your DSL Connection Rate :8.13 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
IP Profile for your line is - 7.15 Mbps
I have tested the speed at different times of the day and get 1.8 - 1.9
I had this a few months ago and Plusnet did some sort of reset and all went back to 7-7.5 (I am very close to the exchange).
Andy
jojopillo
Hi Andy,
I've just popped a ticket over to you explaining the current situation.
Jojo Smiley
andyrpsmith
Many thanks for looking into it.
Andy
jojopillo
Hi Andy,
Have you seen any difference?
Jojo Smiley
