Stuck IP profile - split off
- Stuck IP profile - split off
23-01-2012 3:51 PM
Hi i think ive got stuck IP Profile i ran some tests here my results before the slow down i had about 13600 downsteam
http://www.speedtester.bt.com/
Test1 comprises of two tests
1. Best Effort Test: -provides background information.
Download Speed
7848 Kbps
0 Kbps 21000 Kbps
Max Achievable Speed
Download speedachieved during the test was - 7848 Kbps
For your connection, the acceptable range of speeds is 4000-21000 Kbps.
Additional Information:
Your DSL Connection Rate :9725 Kbps(DOWN-STREAM), 444 Kbps(UP-STREAM)
IP Profile for your line is - 8579 Kbps
Upload Speed
362 Kbps
0 Kbps 444 Kbps
>Upload speed achieved during the test was - 362 Kbps
Upstream Rate IP profile on your line is - 444 Kbps
my Router status
ADSL Status
Parameters
DSP Firmware Version A2pB025f.d22k
DMT Status No Defect
Operational Mode ADSL2+
Upstream 444
Downstream 9726
SNR Margin(Upstream) 26.9
SNR Margin(Downstream) 5.5
Line Attenuation(Upstream) 18.2
Line Attenuation(Downstream) 38.0
jim:green Post split off and title changed as it isn't the same problem mod:end
Download Speed
7848 Kbps
0 Kbps 21000 Kbps
Upload Speed
362 Kbps
0 Kbps 444 Kbps
my Router status
ADSL Status
Parameters
Upstream 444
Downstream 9726
Message 1 of 4
(914 Views)
3 REPLIES 3
Re: Stuck IP profile - split off
23-01-2012 4:32 PM
Hi madmax456,
Your line has been banded to 4864Kbps - 9728Kbps this means that 9728 is the maximum you can sync at. There must have been some issues with the line for this to happen. I could request that to be removed but I'd need you in the test socket before I did that.
Jojo
Jojo
Message 2 of 4
(395 Views)
23-01-2012 6:08 PM
Hi it ok ive put in ticket going to take 72 hours fix it someing wrong at the exchange thank you for the help
jim:quote
jim:quote
Message 3 of 4
(395 Views)
24-01-2012 10:04 AM
HI madmax456,
are you in the test socket?
Jojo
Jojo
Message 4 of 4
(395 Views)
