Stuck IP Profile
- Stuck IP Profile
Stuck IP Profile
21-04-2010 10:41 PM
Can you give it a kick for me - the BT one and the PN one please
Re: Stuck IP Profile
22-04-2010 9:27 AM
22-04-2010 10:20 AM
I have a DG834GT with DGTeam FW..there's a plethora of options but which one do I go for
22-04-2010 10:23 AM
22-04-2010 2:10 PM
Would've preferred to resync this morning as that's obviously when best speeds are achieved.
There's not actually a disconnect option on the DG, that I know of.
I'll have a look for an alternative.
Cheers Matt
22-04-2010 2:26 PM
22-04-2010 2:48 PM
if you disconnect your router from work, how do you thing you will be able to reconnect it?
never mind that you also changed you name, the only way when you get back home is to connect to the router with ethernet, you might have also broken your WiFi connection.
Never muck around with paswwords via WiFi, you can get very lumbered
22-04-2010 3:24 PM
Quote from: Matt If it's only once a day there shouldn't be any ill effects from either powering down or unplugging, so go with that. It's only if there's several within a short timeframe (about an hour I think?) that the DLM will assume a fault.
I think 10 reboots in an hour is the maximum but I wouldn't do more than two personally as with the higher attenuation on my line (down) the noise margin increases just after one reboot never mind two.
Someone (could have been PN Staff but can't be sure) suggested recently that a PPP disconnect followed swiftly by a reboot could fool the exchange, I tried it and the nm went up a bit but came back down again within 26 hours.
22-04-2010 4:27 PM
Quote from: pierre_pierre Oh Mot what are you thinking of?
haha, it was a stupid move - it was still early
Powered down and back up when I got home, IP profile has now raised.
Thanks for you help guys
22-04-2010 4:31 PM
Let us know if not.
22-04-2010 4:49 PM
Should I give it a while?
22-04-2010 4:51 PM
22-04-2010 5:04 PM
22-04-2010 5:10 PM
Quote from: mot There's not actually a disconnect option on the DG, that I know of.
There is on my DG834: Diagnostics, Reboot!
22-04-2010 5:15 PM
