Stuck Emails in O E 6 in box
- Stuck Emails in O E 6 in box
01-10-2008 7:11 PM
I seem to have an E mail stuck in the process of going to my in box the top bit is downloaded but not the body and atachment this is being repeated many many times ,same mail, I get the message Your Pop 3 server has not responded etc. is this mail stuck in my system or is it Plusnet If my fault how can I remedy It Thank You
Message 1 of 4
(1,606 Views)
3 REPLIES 3
Re: Stuck Emails in O E 6 in box
01-10-2008 7:29 PM
Try logging into Webmail and deleting it.
Message 2 of 4
(384 Views)
01-10-2008 7:37 PM
Thanks for that it seems to have solved the problem
Message 3 of 4
(384 Views)
03-10-2008 4:26 PM
Well Well it was you lot after all. Never mind
Message 4 of 4
(384 Views)
