Strange speedtest results
- Re: Strange speedtest results
08-03-2012 9:54 PM
Hi
PN's Mybroadbandspeed.co.uk always used to report my download speed at approx 5600 kpbs - OK for 6000 kbps PN profile.
However, recently Mybroadbandspeed.co.uk has been reporting download figures below 3000 kbps.
Tonight (8/3/12) @ 21.35 I undertook some tests:
Mybroadbandspeed.co.uk = 1723 kbps
speedtest.net = 3710 kbps
Hmmm some difference, but the surprise was the BT wholesale speed tester which reported 5.71 Mbps, which is spot on!
I am wondering what could cause this?
All the tests were undertaken on a wired ethernet PC running Ubuntu 10.04 & the Chrome browser.
Richard
Richard
Message 1 of 7
(1,476 Views)
6 REPLIES 6
Re: Strange speedtest reults
08-03-2012 10:27 PM
mybroadbandspeed is currently borked.
Picking a different host on Speedtest.net would probably mean you get a decent test. I usually use London (provided by Trance FM) as it seesm the most reliable for 40meg+
Maidenhead is also adequate for slower speed
Providing BT speedtester is Okay - theres nothing to worry about
Regards
Regards
Message 2 of 7
(570 Views)
09-03-2012 7:26 AM
Hi
Thanks for the response
I will try some more speed tests when I am back from work.
I cannot see anything on the PN service status about mybroadbandspeed.co.uk being borked.
Could a PN rep please advise?
Richard
Richard
Message 3 of 7
(570 Views)
09-03-2012 9:12 AM
A big difference for me this morning between mybroadbandspeed (1.4Mbps) and Speedtest.net (11.4Mbps). Noticed similar results recently. A bit hit or miss as sometimes mybroadbandspeed shows comparable results to other test sites at around 11Mbps.
Message 4 of 7
(570 Views)
10-03-2012 3:57 PM
I'm seeing very odd download speeds from mybroadbandspeed. speedtest.net gives me the speeds i'm expecting. no indication that mybroadbandspeed is rogered.
Message 5 of 7
(570 Views)
10-03-2012 8:10 PM
Quote mybroadbandspeed is currently borked.
the site works fine, it just isnt having enough throughput for the speedtester to be of any real use. JoJo i think commented on this on the forum.
Regards
Message 6 of 7
(570 Views)
10-03-2012 8:35 PM
As others have mentioned, it is probably to do with the "mybroadbandspeed" problems. But, it might be worth posting your router stats to see if there is anything else wrong.
Message 7 of 7
(570 Views)
