Strange speed variations on new fibre connection.
- Re: Strange speed variations on new fibre connecti...
19-11-2013 9:12 AM
Hopefully someone could shed some light onto this for me?
I've recently had fibre installed - I run several linux machines at home which generally look like this in regard to throughput
Resolving download.thinkbroadband.com (download.thinkbroadband.com)... 80.249.99.148, 2a02:68:1:7::1
Connecting to download.thinkbroadband.com (download.thinkbroadband.com)|80.249.99.148|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 1073741824 (1.0G) [application/zip]
Saving to: `1GB.zip.1'
5% [==> ] 64,064,864 6.71M/s eta 3m 32s
The same download via my Windows 7 machine returns speeds of about 1.7mb/s down. I've used three different NICS plus one USB>Ethernet NIC which all yield the same results. However the speedtest.net speedtest shows results of 70mbit down. I'm wondering what's going on? This is the same across three different browsers - I did make a post on the forum about this, some profile reset was done and then the speeds resumed to normal, only to drop off again today..
Machine is malware free, no firewall on it causing the issue.
I've changed the ethernet cable three times as as-well.
1. Best Effort Test: -provides background information.
Download Speed
73.2 Mbps
0 Mbps 77.43 Mbps
Max Achievable Speed
Download speedachieved during the test was - 73.2 Mbps
For your connection, the acceptable range of speedsis 16 Mbps-77.43 Mbps .
Additional Information:
IP Profile for your line is - 77.43 Mbps
Upload Speed
15.49 Mbps
0 Mbps 20 Mbps
Upload speed achieved during the test was - 15.49Mbps
We were unable to identify any performance problem with your service at this time.
It is possible that any problem you are currently, or had previously experienced may have been caused by traffic congestion on the Internet or by the server you were accessing responding slowly.
If you continue to encounter a problem with a specific server, please contact the administrator of that server in the first instance.
Using BTHH3 and the BTOR modem.
Cheers,
Ben.
Download Speed
73.2 Mbps
0 Mbps 77.43 Mbps
Upload Speed
15.49 Mbps
0 Mbps 20 Mbps
Cheers,
Ben.
Message 1 of 6
(1,163 Views)
5 REPLIES 5
Re: Strange speed variations on new fibre connection.
19-11-2013 4:49 PM
Hi krs360,
Just so I'm understanding this correctly, are you getting slower speeds when using Windows 7?
Message 2 of 6
(598 Views)
19-11-2013 6:36 PM
Could be just from single threaded - as the per the other post?
Speed test are fine, HTTP downloads are 1/4 of the normal speed I can achieve. Upon using a download manager I can happy achieve the normal speed.. Origin and Steam don't seem effected by this. I'm a bit confused, this is repeatable across Firefox, Chrome and IE..
Fresh install of Windows 7 btw.
Message 3 of 6
(598 Views)
20-11-2013 9:08 AM
Is this the same wherever you try and download from, in terms of HTTP downloads?
Message 4 of 6
(598 Views)
20-11-2013 6:57 PM
Chris, thanks for the reply.
Yes this is consistent across the board.
Multithreaded
Single?
Upload to my hosting provider
Speeds overall are really erratic at the moment, 72mbit one minute, 26 the next. I live 120m from the exchange roughly so the local loop is tiny.
I understand it's possible for the speeds to vary within the first ten days but it's almost like the dls are being restricted somewhere or there's some sort of profile issues.
Ben
Multithreaded
Single?
Ben
Message 5 of 6
(598 Views)
27-11-2013 8:54 AM
Did you ever get a solution for this issue? I ask because a number of us are having the same issue as discused in this post; http://community.plus.net/forum/index.php/topic,120303.0.html
Message 6 of 6
(598 Views)
