Strange broadband 'interruptions' - Anybody else having similar issues?
- Strange broadband 'interruptions' - Anybody else h...
Re: Strange broadband 'interruptions' - Anybody else having similar issues?
20-01-2013 6:36 PM
My issues are daily interruptions in my connection which don't appear to be disconnections but stop all traffic. Check out my TBB monitor link and see the many spikes:
http://www.thinkbroadband.com/ping/share/a7402b9d44b510976fdc05b4e9831c48.html
20-01-2013 6:40 PM
I believe I am suffering from the same problem as you then as I've had a lot of websites stuck on "Loading..." the last few days.
My speed has also dropped dramatically and pings increased too.
I've signed up for the same TBB monitor so should have something to compare to you tomorrow.
20-01-2013 6:46 PM
This is on my FTTC connection at home.
20-01-2013 7:33 PM
20-01-2013 8:00 PM
21-01-2013 10:18 AM
MrPig: That graph doesn't show any disconnections, just the signs of a busy connections. What sort of thing are you seeing?
Grimshield: Slow downs at peak?
Ex-Broadband Service Manager
21-01-2013 10:23 AM
If I manually force my router to connect it does, could there be a fault in the network?
21-01-2013 10:50 AM
21-01-2013 10:54 AM
21-01-2013 10:56 AM
21-01-2013 11:04 AM
My wireless tray icon had a yellow triangle on it. Signal strength excellent but when I open up Netwrk & Sharing Center in control panel it says limited access.
21-01-2013 11:56 AM
What router are you using?
dick:quote
21-01-2013 12:04 PM
Quote from: Kelly Zico: I think you've got something more sinister going on. A fault perhaps. Do you have a different router to try?
No, no spare router to try.
21-01-2013 12:15 PM
I'm monitoring the situation and so far no failures, it's usually only a brief disconnection. The router is relatively new, Belkin F9J1002V1
Just noticed my output power has dropped to zero! That normal?
21-01-2013 12:33 PM
Quote My wireless tray icon had a yellow triangle on it.
That isn't going to be caused by your broadband connection dropping, that's most likely the connection between your computer and router. Can you try using an ethernet cable and see if you still see as many disconnections?
