Stogi: Constant Disconnects.
- Re: Stogi: Constant Disconnects.
07-08-2015 4:06 PM
Any more news on this? This is happening to me too. The last week or two, lots of disconnects. As far as I could tell (no disconnects anyway) all was rock solid. So, why now. I have changed nothing my end, already contacted support and yes, I too have to do this fault thing. Thing is, I can't plug into the test socket for three days!! Some of my kit is wired. There must be something going on, no?
Is there anything else I can do, apart from the three day test thing?
adie:green amended thread title
Message 1 of 8
(981 Views)
7 REPLIES 7
Re: Constant Disconnects.
07-08-2015 4:08 PM
Just happened again. Sigh. Restarting my router, again..
Message 2 of 8
(718 Views)
07-08-2015 4:15 PM
mod:note
split from other topic for better visibility.
Message 3 of 8
(718 Views)
07-08-2015 4:21 PM
Message 4 of 8
(718 Views)
10-08-2015 2:37 PM
I can stick in the test socket while you run a test? But, three days is impossible for me. Maybe we've reached the end. The only other thing I'm prepared to try is a new router. Already changed the filter thing. I just don't get these types of problems. Are you sure nothing has changed your end? The exchange? Going to run a quiet line test...
Message 5 of 8
(718 Views)
10-08-2015 2:48 PM
OK, line sounds quiet. Not like it means much. Heard a little bit of noise, but, I think that was my service restarting, again. Going to give you guys a call.
Message 6 of 8
(718 Views)
10-08-2015 3:10 PM
Maybe someone can see something if you can post the stats from your router.
How do you currently connect to the internet - wifi or ethernet cable.
When you say you cant connect the router to the Test socket is how is it connected?
To the outer faceplate plate with a filter or at the end of an extension or something else.
The Radius shows a lot of drops - when you restsrt your router ( what make and model?) do you just switch it off/unplug it
or do a graceful resync using the disconnect facility after logging in to the router
Message 7 of 8
(718 Views)
10-08-2015 4:17 PM
The line is still dropping pretty frequently.
I've tested the phone line and it's not showing any faults, doesn't mean there aren't any but none were detected during the test.
A full broadband test was attempted but the line was out of sync at the time.
I'd strongly suggest reporting this to us at https://faults.plus.net
Message 8 of 8
(718 Views)
