Steam Down?
- Re: Steam Down?
Steam Down?
26-09-2011 11:10 AM
Good morning all, is anybody else having issues with Steam this morning?
The site is OK if I use a remote server, but I can not get to it from my Plusnet connection. Problem at BT?
Can anything be done?
Tracing route to store.steampowered.com [63.228.223.104]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms 192.168.1.1
2 14 ms 18 ms 14 ms lo0-homesurf.ptn-ag02.plus.net [195.166.128.54]
3 14 ms 14 ms 13 ms gi2-7-705.ptn-gw01.plus.net [84.92.3.97]
4 14 ms 13 ms 13 ms t2a1-ge2-0-0.uk-lon1.eu.bt.net [166.49.211.45]
5 14 ms 13 ms 13 ms t2c2-ge6-0.uk-lon1.eu.bt.net [166.49.135.12]
6 14 ms 33 ms 26 ms t2c1-p4-0.uk-glo.eu.bt.net [166.49.208.145]
7 t2a1-ge6-0.uk-glo.eu.bt.net [166.49.135.230] reports: Destination host unreachable.
Trace complete.
Message 1 of 8
(1,405 Views)
7 REPLIES 7
Re: Steam Down?
26-09-2011 11:16 AM
Works from here but a totally different routing
1 <1 ms <1 ms 1 ms 192.168.0.1
2 35 ms 35 ms 35 ms lo0-central6.pcl-ag01.plus.net [195.166.130.87]
3 35 ms 34 ms 34 ms gi7-1-162.pcl-gw02.plus.net [84.93.255.83]
4 34 ms 34 ms 34 ms 195.50.122.129
5 35 ms 35 ms 34 ms ae-52-52.csw2.London1.Level3.net [4.69.139.120]
6 34 ms 34 ms 34 ms ae-59-224.ebr2.London1.Level3.net [4.69.153.141]
7 102 ms 105 ms 102 ms ae-41-41.ebr1.NewYork1.Level3.net [4.69.137.66]
8 105 ms 107 ms 108 ms ae-2-2.ebr1.Newark1.Level3.net [4.69.132.98]
9 104 ms 104 ms 103 ms ae-1-51.edge2.Newark1.Level3.net [4.69.156.9]
10 103 ms 103 ms 103 ms 4.68.111.70
11 104 ms 104 ms 103 ms ewr-core-01.inet.qwest.net [205.171.17.153]
12 * * * Request timed out.
13 183 ms 183 ms 222 ms 63-234-174-50.dia.static.qwest.net [63.234.174.50]
14 * * * Request timed out.
15 192 ms 195 ms 193 ms store.steampowered.com [63.228.223.104]
Trace complete.
Trace complete.
Message 2 of 8
(680 Views)
Re: Steam Down?
26-09-2011 11:21 AM
Having the same problem since last night. Been away since Thursday but when i logged in last night first steam prompted me for username and password which it does not do usually.
Then when I clicked on either Deux Ex or Space marine I get a window saying Completing Updates. It sticks at 2% on both and does not proceed.
Weirdly I can connect and play some games (Dead Island for 1) but cannot connect to the steam forums either.
Hypo
Hypo
Message 3 of 8
(680 Views)
Re: Steam Down?
26-09-2011 12:00 PM
I'm also affected, I'm in the West Midlands and routed on the same path as you.
Can't access the Steam forums, the store and games like Human Revolution aren't working, I think because they can't connect to the DRM servers.
Message 4 of 8
(680 Views)
Re: Steam Down?
26-09-2011 12:27 PM
Thanks for confirming that Oldjim
I changed to a different gateway (Disconnected and reconnected in the routers configuration screen)
And now am on thn-ag1 and Steam is working again :).
As you say its a different routing.
Hopefully Somebody at plusnet will pick this up and get it fixed so that others don't suffer the same problem. I would imagine it is causing other issues as well not just steam.
But for now those that have the problem (and read this forum) can fix it by Gateway Hopping!
Message 5 of 8
(680 Views)
Re: Steam Down?
26-09-2011 12:59 PM
Seems they have changed the routing to use multi transit hosts to USA and its affecting gaming, speed and packet loss issues if its via BT.
http://community.plus.net/forum/index.php/topic,98818.0.html
Quote Routing will indeed be different based on gateway, it may also be different from one minute to the next on a single gateway (though not likely to flip too often). This is the nature of our core network between three sites and the connectivity available from there.
FTTP 500 regrade from Tues 28th November
Message 6 of 8
(680 Views)
Re: Steam Down?
26-09-2011 1:19 PM
Ah, wondered what was happening - I was getting random disconnects and connection interrupts on Black Ops all weekend, was a pain in the proverbials. Hopefully it'll all get sorted soon but it does seem to be a steam side issue 😕
Message 7 of 8
(680 Views)
Re: Steam Down?
26-09-2011 2:11 PM
This seems to be a widespread problem.
Over at the BT forum, it's thought to be something to do with BT's network:
http://community.bt.com/t5/BB-Speed-Connection-Issues/BT-vs-Steam/td-p/292193
On the overclockers forum, more and more people are discovering they have a problem with steam:
http://forums.overclockers.co.uk/showthread.php?t=18322195
Edit: forgot to add. I'm having the problem too, on both ptn-ag01 and ag04.
Message 8 of 8
(680 Views)
