Static IP for WiFi device
- Re: Static IP for WiFi device
23-12-2013 4:45 PM
I have a Technicolor TG582n router and I want to be able to assign a static IP to a RasPi connected via WiFi.
I have done this for when it is connected via cable OK (configure the connected device and tick teh static IP address tick box and apply) but doing the same doesn't work for the wifi connection?
Any Ideas why/what i can do?
Cheers
Grebby
Cheers
Grebby
Message 1 of 3
(564 Views)
2 REPLIES 2
23-12-2013 5:26 PM
If you're OK with using telnet to access the router then you can get it to fix DHCP leases by Mac address. See here http://npr.me.uk/telnet.html , the section titled 'change Lan IP of a connected device'
Message 2 of 3
(350 Views)
23-12-2013 6:19 PM
Thank you.
That seems to have worked
Now just got to sort out the RasPi
Message 3 of 3
(350 Views)
