Static IP - disappeared :-(
- Re: Static IP - disappeared :-(
06-11-2008 4:48 PM
How can I get back my disappearing IP address? I need it
06-11-2008 5:42 PM
Member Centre>Connection Setings>Control Your Broadband and select "Change IP Settings"
Direct link.
Did you recently change product per chance? Static IPs seem to be lost unless you add a note to the regrade ticket askingto keep your static IP.
06-11-2008 7:03 PM
07-11-2008 9:32 AM
Cheers
Foxy
07-11-2008 10:18 AM
You get a DNS name which will always point to your current IP address. When your modem connects it logs in to the service to tell it your current IP address. I use RIN where I get dynamic IPs and sometimes the normal Plusnet centrals when I get my static IP and it just works.
13-11-2008 11:52 AM
However, my static IP has changed again!! I did go over my bandwidth usage, is this why it's changed again? A bit frustrating as I've got to drive 20 miles to fix it...
13-11-2008 12:08 PM
13-11-2008 12:12 PM
I see more problems (elsewhere admittedly) of people wanting to change IP (one does wonder why ) when they're on dynamic but it never changes.
13-11-2008 2:07 PM
Hmm interestingly it looks like you have 2 static IPs in RADIUS, so I *think* that what's happened is when you hit the data transfer cap, it automatically raises a ticket (due to your RIN component needing a dynamic IP and you having a static) and the agent has then added a new IP component which has overwritten your previous one but left traces of it in RADIUS. I've just kicked your IP component and RADIUS looks happy again now.
The simple way to fix this would be if you don't use the RIN login (@plusdsl2.net) I can remove the component from your account and this should stop this happening in future.
13-11-2008 3:22 PM
