Static IP address on LAN - dhcp ip reservation
- Static IP address on LAN - dhcp ip reservation
- « Previous
- 1
- 2
- Next »
Re: Static IP address on LAN - dhcp ip reservation
14-11-2013 11:08 PM
Your server is showing as 'Unknown' so you can't see the setting...
Try looking at all the devices on the Home Network page (or perhaps easier, plug the server into a LAN port directly) to make sure the server doesn't appear elsewhere in the list as well.
14-11-2013 11:40 PM
15-11-2013 8:41 AM
So it wuld appear that the settings on my router need to change or on my server ?
15-11-2013 9:02 AM
Try the other devices in the list one by one until you find a corresponding entry that shows the current address for your box and that the assignment has been via DHCP.
15-11-2013 9:27 AM
I have looked at all the devices with a wired connection and none of them have the magic tick box.
Has this got something to do with the attached screen shot?
15-11-2013 10:00 AM
Do all your devices show 'unknown' against 'IP Address Assignment'?
15-11-2013 10:05 AM
For clarity - have you configured fixed IP addresses in the PCs? To confirm this, launch a CMD window and type 'ipconfig /all' (without the quotes) and look for a line which reads 'DHCP Enabled=Yes' (or similar). If this states "No" then in the first instance there is a problem at the PC end as it is not using DHCP. Confirm / fix that first.
15-11-2013 10:14 AM
Ok it looks like I can fix the IP address on my laptop but not my server take a look at the attached screen shots.
15-11-2013 10:18 AM
PS there is no merit in obscuring the 192.168.1.xxx IP addresses - we all have those addresses in our private networks. It is the external IP which correctly should be obscured.
16-11-2013 3:43 PM
It would appear that it was a setting in the server config and this has been changed which has allowed me to FIX the IP. See attached screen shot.
Thanks for all your help!!
The next part of this problem is the IP address that I have it fixed to is .66 and I would like to switch it back to .68. Does anyone know how to change the IP address?
17-11-2013 9:33 AM
17-11-2013 10:21 AM
17-11-2013 10:47 AM
Yes just played about with it and got it all sorted thanks for all your help guys.
- « Previous
- 1
- 2
- Next »
