Staggeringly poor speeds tonight 17/04/08
paulh
Terrible speeds tonight -- both BBMAX and MyBroadBandSpeed are showing 300-350kbps instead of my usual 3000-5000.
i'm on thn-ag3 and synced as normal at 761600, stable rate  6500.
can't get on the BT speedtester at the  moment -- will report back -- but is there a problem tonight for others?
paul
11 REPLIES 11
pierre_pierre
Re: Staggeringly poor speeds tonight 17/04/08
Could be this Whoops
paulh
hmmm maybe ... i've been connected to thn-ag3  for nearly 400 hours continuously but i might try a gateway-hop
chillypenguin
That service status was announcing additional capacity, so very  unlikely to cause slow speeds.
edgeways
I am experiencing similar drasticaly slow speeds tonight. One speed test showed download speed slower than upload!!! I too am connected to THN ag3
Looks like the additional pipe capacity  has had the opposite to desired effect.
jelv
Fixes: 10
I think when a new segment is activated they change the priorities to try and populate it quicker. Looks like they may have over-cooked it!
Live graph of THN-AG3
I suggest trying another gateway - compare the current state of the gateways here
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Saturn
I have similar results and am on the same gateway.  I've noticed PN speed has been progressively slower for a while.  Tonight is diabolical.
jelv
Fixes: 10
The other gateways are all looking good - trying disconnect/reconnect until you get a different one.
Kelly
Fixes: 9
Guys, something is definitely wrong.  I'm talking to James and the CSC staff right now.
Kelly Dorset
Ex-Broadband Service Manager
James
Cheers guys.
Just called CSC and they're about to call Networks out.
Kelly
Fixes: 9
P1 raised:
http://www.plus.net/support/service/problems/problem.php?intProblemId=51181
Kelly Dorset
paulh
The system works ... Smiley
