Stable Rate - What do we do?
- Stable Rate - What do we do?
08-01-2008 3:58 PM
Re: Stable Rate - What do we do?
08-01-2008 4:04 PM
08-01-2008 4:11 PM
If you read the speed sticky in this forum and also the speed link in my signature, this should help to explain why this is happening.
It is actually the BT profile (of which we have no control over) that is being changed and then subsequently mapped on our platform.
This has happened because you reconnected at a very low speed at 7pm on the 5th. It should pick up again in the next 24 hours.
08-01-2008 4:47 PM
I've just manually mapped BTs profile of 1500Kbps against your account, so if you reboot you should see an improvement in speeds.
I'm not sure what that means but I guess it was supposed to make things better quicker. What are we supposed to do - raise a ticket?. Can we do a similar thing ourselves? Thing is - I've been stuck on 500K for at least 2 days. No doubt it will build up at its own leisurely pace but this is 2008 and there really should be a way to override the stupid Max process.
08-01-2008 4:52 PM
Our profiles are mapped against BTs on a twice daily basis.
BTs profiles are generally recalculated once every three days, so your having waited for two days is within the design of the product.
I do appreciate it is annoying and it is one of the most frustrating areas of the IPStream Max product. If you have a look at the link I've referred to, this is described in detail.
08-01-2008 5:07 PM
[Moderator's note by Peter (PJ): Removed username and e-mail address for privacy reasons and to prevent spam bots gathering them]
08-01-2008 5:13 PM
[Moderator's note by Peter (PJ): Removed username for privacy/anti-spam reasons]
08-01-2008 5:21 PM
09-01-2008 9:54 AM
IP profile for your line is - 1750 kbps
DSL connection rate: 448 kbps(UP-STREAM) 2368 kbps(DOWN-STREAM)
Actual IP throughput achieved during the test was - 447 kbps
That suggest BT are trying to give me closer to me 2.3G but Plus are choking it. Does this have to wait for a periodic update to your systems? Is this the process you overrode before?
09-01-2008 10:00 AM
DSL Connection Rate: This is the speed at which you are connecting with the exchange at.
IP Profile: This is the speed at which BT are restricting your line speed to.
IP Throughput: This is your download speed.
I've had a look at your account and our profiling hasn't vaught up with BTs. I've since amended this and if you reboot your router, you should see an improvement in speed.
09-01-2008 10:32 AM
Maybe you could comment on why Plus has to set it's own rate? I would have thought you stream data at the maximum line speed. BT are throttling it to reduce error packets - or something like that - but I don't understand why you want to set limits on speed.
Can you not make representations to BT to allow IP profile speeds to be user-controlled more?
09-01-2008 10:49 AM
You are back on 1.5Mbps because BT have set a profile of 1.75Mbps, which after overheads, leaves your 1.5Mbps.
We set our own profile as there is less packet loss on our network than there is on the BT network. This means that we are able to optimise your speeds against the IP Profile more efficiently than BT.
In short, PlusNet > BT.
Regarding BT allowing user implemented IP Profiling, this will never happen as it would lead to a subsequent increase in faults from the less clever ISPs randomly tinkering around. It's part of the reason that BT started charging for engineer callouts in the first place after various ISPs would merely raise faults without doing any form of diagnosis work and in some cases BT would send an engineer to fix a fault to find that the modem wasn't even plugged in!
