Spring Cleaning the Portal - Suggestions for alternate tools
- Re: Spring Cleaning the Portal - Suggestions for a...
- « Previous
- 1
- 2
- Next »
Re: Spring Cleaning the Portal - Suggestions for alternate tools
17-03-2008 9:53 PM
The Royal Mail one has a habit of being VERY picky about spelling.
For example the place where I live has a "saint" in the name which they INSIST is spelt "st.". If you enter the place name with just "st" or "saint" it doesn't find it.
But you can use a truncated form and then choose, so it's not that bad really....
Message 16 of 19
(293 Views)
17-03-2008 11:41 PM
Yup. I live in Letchworth Herts. But the Post Office insists on the full name Letchworth Garden City - which hardly anyone uses including the Map makers!
M
M
Message 17 of 19
(293 Views)
04-04-2008 1:35 PM
So how do I set up a small mailing list?
Message 18 of 19
(293 Views)
04-04-2008 7:30 PM
Quote from: Tamlyn
Quote from: scootie i know its not a great deal to go to connection settings then to usage data but it would be handy to be able to see this usage data as soon as u login.
We're currently looking into 'widgetising' the member centre in a similar style to iGoogle and the new bbc homepage so that everyone can customise it with exactly the information they want. It's won't happen in the next few months but most of agree that it's The Way To Go. We may even be able to fix it so that you can see your usage/billing info from the igoogle homepage without even visiting the member centre!
Like the sound of that
Bob - does the 'weebly' wobble and never fall down?
Message 19 of 19
(293 Views)
- « Previous
- 1
- 2
- Next »
