Speed slower
- Speed slower
- « Previous
- Next »
Re: Speed slower
13-06-2012 2:48 PM
Regarding the reporting error, I'm not sure this is worth worrying about at present given that the speed has increased to the level it is currently (somewhat above what the BT engineer advised would be possible on the line) and is also likely something that will most likely change on the next resync or reboot of the router.
Fully appreciate what you're saying about previous problems but given that things have improved (and further, improved as our faults agents advised things would do) it may be worth going with that and letting things settle before searching for any remaining issues. Anything serious will no doubt make itself very apparent in short order.
@Kaotik - Not sure about that one. I believe the reset that the engineer did should have reset that and let it retrain, but that may not be the case.
I'd rather leave things until tomorrow before attempting any changes if that's alright, but I'll check the profile first thing tomorrow and reset it if nothing's changed if that's okay with you?
Re: Speed slower
13-06-2012 3:12 PM
thanks
Re: Speed slower
14-06-2012 9:07 AM
I've done some tests and the profile on your line has gone up to 6500 so I've matched that on our side, hope you're seeing that speed - if not please let me know and I'll reset the profile as I mentioned above.
It looks like interleaving has also been removed from the line so that should improve speeds a bit too.
Hope things are working much better for you, please let us know
Re: Speed slower
14-06-2012 9:33 AM
In regards to interleaving is that off now? cuz theres no improvement in my ping, its still 40+
Re: Speed slower
14-06-2012 11:49 AM
Re: Speed slower
14-06-2012 12:45 PM
Re: Speed slower
14-06-2012 1:11 PM
Re: Speed slower
14-06-2012 1:17 PM
Quote from: Anotherone I think he's forgotten your modem/router doesn't appear to (readily anyway) report the errors
Can't see it mentioned in this thread, though I have to admit I haven't looked over all the others to check. The information posted looks like it came from a Netgear, I'm not sure if those errors are on a different page to the status pop up though - been a while since I played with a Netgear.
@KaotiK The report I checked should be fine regarding interleaving, and it's definitely showing off at the moment as I posted earlier.
Re: Speed slower
15-06-2012 10:41 AM
Re: Speed slower
15-06-2012 11:28 AM
Re: Speed slower
15-06-2012 1:21 PM
Re: Speed slower
18-06-2012 6:11 PM
Re: Speed slower
20-06-2012 9:42 AM
We'll keep an eye on things, but let us know if it does get too bad and we'll see what we can do.
- « Previous
- Next »
