Speed slowdown
- Re: Speed slowdown
Speed slowdown
30-05-2010 8:41 AM
last day or so I have noticed a slowdown on my broadband speed. Just done some speed tests,
tests were performed with the Netgear router plugged into the master socket, no extension cables.
Everything was fine a few days ago. I believe I am on 21cn as doing some speedtests last week, I was getting around 9-10 mbs.
tried to raise a ticket but all I got was "This fault checker is for ADSL products only. Please use the Help Assistant to report a problem with your account."
Hope you can help.
The Performance Tester is now testing Broadband connection. Your configured download throughput speed for this service is 135 k
Download speed achieved during the test was - 63 Kbps
For your connection, the acceptable range of speeds is 50-135 Kbps.
Additional Information:
Assured Rate IP profile on your line is - 135 Kbps
Hope you can help.
Message 1 of 5
(960 Views)
4 REPLIES 4
Re: Speed slowdown
30-05-2010 9:08 AM
Your router stats will indicate your ADSL connection and the general rule appears to be test the connection with the offical BT speed tester for accurate results [www.speedtester.bt.com] then post the results for both
Message 2 of 5
(498 Views)
Re: Speed slowdown
30-05-2010 10:07 AM
BT Speedtest results in first post.
Router stats:
ADSL Link Downstream Upstream
Connection Speed 283 kbps 440 kbps
Line Attenuation 35.5 db 16.3 db
Noise Margin 25.3 db 29.0 db
Router stats:
Message 3 of 5
(498 Views)
Re: Speed slowdown
30-05-2010 10:51 AM
Is there any noise on the line when you use your phone?
Have you got any other extensions (used or unused) - if so can you try using the test socket inside the master socket.
Can you reboot your router and then post the router stats.
Message 4 of 5
(498 Views)
Re: Speed slowdown
30-05-2010 11:12 AM
Did a quiet line test, no noticable noise.
There are other extensions, but have unplugged them and plugged directly into the test socket.
BT speedtest results:
Download speedachieved during the test was - 51 Kbps
For your connection, the acceptable range of speedsis 50-250 Kbps.
Your DSL Connection Rate :283 Kbps(DOWN-STREAM), 444 Kbps(UP-STREAM)
IP Profile for your line is - 135 Kbps
The throughput of Best Efforts (BE) classes achieved during the test is - 15.69:33.33:50.98 (SBE:NBE:PBE)
Router stats after reboot:
Connection Speed 283 kbps 444 kbps
Line Attenuation 35.0 db 16.3 db
Noise Margin 25.7 db 28.4 db
Message 5 of 5
(498 Views)
