Speed - profile capped at 2mb when line sync 8.128
- Re: Speed - profile capped at 2mb when line sync 8...
28-02-2014 9:24 PM
Hi
I had my broadband was activated today and the line details are as follows
Bandwidth (Up/Down) [kbps/kbps]: 448 / 8.128
however when I do a speed test I'm only getting 2mb.
Please can someone check my profile is correct.
Message 1 of 3
(583 Views)
2 REPLIES 2
Re: Speed - profile capped at 2mb when line sync 8.128
28-02-2014 9:27 PM
Given that there may not be any staff on here until Monday can you check two things - BT Speed test - further diagnostics and the Plusnet profile
This explains http://community.plus.net/forum/index.php/topic,96155.0.html
Basically as you are on ADSL1 20CN exchange either may be stuck
I assume that your exchange isn't 21CN enabled http://usertools.plus.net/exchanges/
Message 2 of 3
(348 Views)
03-03-2014 2:33 PM
Hi sebeye,
I'm sorry to hear you're experiencing slow speeds.
I have checked your account and can confirm that you are on the correct connection profile. I have also checked your line and your connection profile matches the speeds your line should be getting. Are you testing your speed through a wired connection?
If your speeds are still low then I would suggest that you raise us a fault here: http://www.plus.net/support/broadband/bbfaults/
Our Faults team will then be able to investigate further and they'll update you on your account.
Message 3 of 3
(348 Views)
