Speed of connection good - webpage loading very slow
- Re: Speed of connection good - webpage loading ver...
09-01-2016 5:34 PM
Tracert suggests (below) slow resolution by plusnet? IP addresses no quicker. Any suggestions?
Tracing route to www.bbc.net.uk [212.58.246.55]
over a maximum of 30 hops:
1 <1 ms 1 ms <1 ms www.routerlogin.com [192.168.0.1]
2 358 ms * 360 ms lo0-central10.pcl-ag08.plus.net [195.166.128.189]
3 405 ms 352 ms 345 ms link-b-central10.pcl-gw02.plus.net [212.159.2.190]
4 427 ms 327 ms 407 ms xe-9-1-0.pcl-cr02.plus.net [212.159.0.222]
5 387 ms 469 ms 428 ms ae1.ptw-cr02.plus.net [195.166.129.2]
6 464 ms 476 ms 378 ms ae2.ptw-cr01.plus.net [195.166.129.4]
7 590 ms 609 ms 618 ms kingston-gw.thdo.bbc.co.uk [212.58.239.6]
8 * * * Request timed out.
9 567 ms 509 ms 493 ms ae0.er01.cwwtf.bbc.co.uk [132.185.254.93]
10 * 581 ms 488 ms 132.185.255.165
11 514 ms 613 ms * bbc-vip046.cwwtf.bbc.co.uk [212.58.246.55]
12 535 ms 509 ms 557 ms bbc-vip046.cwwtf.bbc.co.uk [212.58.246.55]
Trace complete.
Re: Speed of connection good - webpage loading very slow
09-01-2016 5:59 PM
D
11-01-2016 10:16 AM
A warm welcome to the forums.
...more to the point, One Drive must have been hammering the link, thereby causing the much lower priority ping traffic to be dropped. It would be worthwhile looking at your one drive settings and adjusting them so as to not utilise all of the available bandwidth.
11-01-2016 4:33 PM
Thank you.
11-01-2016 5:18 PM
Drop-box does have the ability to limit the bandwidth it consumes - I rather expected one-drive to do the same. I do not use one-drive, but having just taken a peek at it, I cannot readily discern any similar controls May be someone with a better working knowledge of one-drive can advise if there is something hidden some where. MS products usually do have controls, but not in the place you'd expect to find them!
11-01-2016 5:28 PM
