Speed now dropped to approx 2.5 mbps!
- Speed now dropped to approx 2.5 mbps!
11-11-2007 3:10 PM
Re: Speed now dropped to approx 2.5 mbps!
11-11-2007 3:28 PM
Regards, P.
11-11-2007 6:09 PM
perhaps similar to what happened to me yesterday. (Usually 5500/6000kbps throughput, but had dropped to sub 2500kbps on downloads.
I checked my stable rate on the portal (down to 2500kbps from 6000kbps) and used the BT speed test (took a silly number of tries to get it to run) and it showed a bras of 2500kbps, indicating that there had been a bad synch on my line that day. (Probably wind and rain affecting the long overhead wires here).
I rebooted the router and synched closer to usual speeds, but of course throughput was then restricted by the bras rate of 2500kbps.
Then this morning when I booted up the router etc, it showed perfectly normal synch rates for me of 7616kbps.
My stable rate on the portal showed 5500kbps (a little down on usual), and throughput matched this on downloads.
So I guess that BT's recent changes to the way bad synchs are handled seems to work well! IE; My line speed came back this morning instead of waiting for 3 days, as it used to be.
12-11-2007 9:07 AM
12-11-2007 9:22 AM
We had a bit of a problem with one of our gateways over the course of the weekend. This resulted in our other gateways being more congested than usual. This means that for some of our customers who will have been connected to our busier gateway, may have seen slower download speeds than usual.
I've also run a couple of checks on your line and can see that your sync rate nor profile have changed, so once we see a balance across our network, your speeds should be fine. It may be an idea to try rebooting your router and then see if you experience an improvement in your speed.
12-11-2007 6:12 PM
Quote from: esseff How do I check my stable rate on the portal?
Hi esseff, you can bookmark this link; https://portal.plus.net/my.html?action=stable_rate
Following the post by Jameseh, it is obvious that your speed issue is not related to a bad synch, as was the case for me.
13-11-2007 5:01 PM
13-11-2007 9:09 PM
i managed a staggering 780kbps.... My speed has been dropping since i joined PN...
whats going on support? please give me my speed back.. Im slower now than when i was with Pipex.
14-11-2007 8:59 AM
14-11-2007 9:10 AM
Can I ask you if you have tried rebooting your hardware? I've run a test on your line and you're showing as being profiled as 5Mbps at both our and BTs end.
We did experience some gateway difficulties yesterday afternoon which may have resulted in some customers seeing poorer speeds.
Let me know how you get on.
